« 1 (2) 3 4 5 6 »
Re: Black 1200 Ute Build
From Brisbane
i bght my blocks from autobarn haha they were in a ratty half opened plastic container with a sticker saying datsun 1200 blocks n theyre sweeeeet:) payed like 25 for them:)
Posted on: 2009/3/28 13:35
From Rosewood, QLD
haha i got ripped off with my blocks damn ebay
im not sure how long its going to take to get running... motor 1 will be getting torn down for a possible rebuild with the addition of some tomei cams, motor 2 and gearbox will be used for test fitting to get the gearbox crossmember sorted so very shortly i will be pulling my seats and carpet out to chop the trans tunnel out, then fix the crossmember, weld the trans tunnel then try to remount my seats... this is all leading to the set back i am faced with at the moment and that is finding some rims with the correct offset to fit over my calipers... im very keen to get it off the jack stands for a while
i have an auto-elec organised which i will be able to mostly pay with bottles of scotch which is good but i may be heading to the RAAF in may which will set me back time wise but within the next 4 weeks i hope to have the first trial fitment done of motor 2 and box
Posted on: 2009/3/28 14:29
1971 B110 sedan project.
2012 Nissan Micra daily.
From Rosewood, QLD
most of my interior has been removed today excluding the dash
whats the best way to get rid of the tar-like sound deadening crap?
i want to strip it all back and smash the floor with rust converter/protection then lay better sound deadener, can someone guide me towards the best rust converter/protection i should be using to keep my floor nice?
Posted on: 2009/4/5 10:38
From perth airport
dry ice or normal ice removes that stuff dude ;)
Posted on: 2009/4/5 13:35
perth airport parking
Datsun 1200 ute A14
From Nyngan, nsw Australia
"the best rust converter" there all much the same as each other, i use septone,
and as for sound proofing im using dynamat than underlay, just that bit extra quiet....
Posted on: 2009/4/5 21:39
living is good,.....
From Rosewood, QLD
so far the lowering blocks have been the biggest pain in the ass to fit but after having the ass end up in the air for so long when i put it back on the ground it looks so much lower and sweeter
TRX rims do fit!!! soon i will be able to put the front end on the ground again too!!!
next on my list of things to do is chop the trans tunnel, trial fit of motor and box, secure gearbox crossmember, lip/flare wheel arches, fit brake booster.... i want to do at least a couple of these things before i go away for basic training in less then a month
Posted on: 2009/4/20 10:55
From newcastle
just cut my trans tunnel out last night for a skyline stumpy box, just so i can trial fit it and get my gearbox crossmember welded up and bolted in can post some pics of the job if you like
Posted on: 2009/4/23 2:25
at first you dont succeed, cut a bit out and put a bigger one in!
85 1200 ute ca18det project build
From Rosewood, QLD
ok just finished chopping out my trans tunnel... next time i do something like that i want the car up on a hoist or much larger jack stands i feel like a have shards of datsun steel imbedded in my face lol
hopefully tomorrow if there is time i will atempt to engine 2 and the box into the engine bay and begin on sorting out the gearbox cross member, im excited.
Posted on: 2009/5/2 7:11
From Rosewood, QLD
trial fitment 1 has been a failure... if only i had a car hoist.
tomorrow ill rearange my strapping and hopefully it will give me the angles i need to slip the bad boy in otherwise i will have to remove the gearbox and do the fitment in 2 stages.... not real fun trying to lift a sr20 5 speed off the ground whilst laying on your back lol
mental note... next time doing this conversion tilt tray car and motor to mates workshop and use car hoist for this bit, everything else has been ok so far lol.
Posted on: 2009/5/3 11:06
From Wagga Wagga, NSW
Its coming along big fella!
Posted on: 2009/5/13 11:16
« 1 (2) 3 4 5 6 »
