1000 engine mounts
From newcastle, NSW
found a broken engine mount, i rang around for a replacement but to no avail. The guy at the local Rare-Spares didn't even have any.
Does anyone know where i can get some?
Posted on: 2009/3/29 11:50
Re: 1000 engine mounts
From newcastle, NSW
Are they the same as the 1200 rubber mounts?
Posted on: 2009/3/29 23:51
From Christchurch NZ
Post a pic Steveo.
Posted on: 2009/3/30 4:30
Forced Induction!
From newcastle, NSW
no they're not! the 1000 has a slanted triangle bit on the bottom side, where as the 1200 rubber mount surfaces that are square to each other.
No problem though, i just simply drilled the spot welds out of the original slanted triange bit and went and got a 1200 mount and modified it to suit, tack welded it together and bobs you uncle! All done!
Posted on: 2009/3/30 4:52
