« 1 2 (3)
Re: reusing CA head bolts???
From Geelong, Vic
it should hold together ok on 10psi....it will go bang if it annoys me enough for me to decide it doesnt really need a wastegate
but until them i'll just assume it will be right
Posted on: 2009/4/2 10:58
From perth
compression is ok IF you pull enough timing out
any boosted engine will lunch itself if it knocks (even once) it doesnt care if you have forgies, a metal head gasket or arp studs
you cant have boost and compression and timing
use the old bolts if they are within spec
Posted on: 2009/4/2 12:43
From Geelong, Vic
dont have the specs to go off and the guy that did the head said he didnt have anything to measure the bolts properly....and found some ARP studs for $200 delivered so will just go with them
i'll leave the computer to sort out any knocking issues...i assume it has a knock sensor for a reason
Posted on: 2009/4/3 8:36
« 1 2 (3)
