#1 indentifying 120y diff
juniorjay Posted on: 2009/4/2 23:59
hello all
i just need to know what diff came standard in a 1977 120y sedan
its pretty urgent
the brake specialist told me it could be either a borg warner or a japanese diff
thanks in advance
Jason
#2 Re: indentifying 120y diff
bert Posted on: 2009/4/3 0:29
Easy as,i assume you have the car there.Look underneath at the diff,if it has a plate on the back of the centre housing its a borg warner,if it has no plate and bolts in from the front(tail shaft end)it's a jap diff.
#3 Re: indentifying 120y diff
juniorjay Posted on: 2009/4/3 0:45
thanks alot mate
nearly 100% sure its a borg warner
im going to the wreckers soonish so ill remember what it looks like
Cheers
#4 Re: indentifying 120y diff
ddgonzal Posted on: 2009/4/3 4:18
Yes, if I recall correctly it was said that 120Y sedans were assembled in Australia and so used aussie-made BW diffs, while coupes were assembled in Japan.
BW 68, has bolts on back of the diff center section
Hitachi diff: bolt are on front of center section
More details and full-size pics: Borg Warner Diff
#5 Re: indentifying 120y diff
juniorjay Posted on: 2009/4/3 10:27
yes it turned out mine was a borg warner
went to the wreckers and picked up another diff
there was about 3 wagons and they all had the japp diff
2 of these were 4 speed manual
im thinking about taking one of the gearboxes for my 120y sedan
are the 120y sedan and wagon gearboxes the same?
thanks again for the help
Jason
#6 Re: indentifying 120y diff
ddgonzal Posted on: 2009/4/3 19:10
Yes, gearboxes are same sedan/wagon/coupe/ute. 120Y and 1200 and Sunny gearboxes are the same
