L series conversion
Quite a regular
From Townsville, Land Down Under
hello people,
im looking at an l18 conversion for my 1200 ute. I just want some advice on whether this is a good conversion (is it worth it?), what kind of things need to be modded, and what kind of power output this will achieve. Any comments would be appreciated. I'm getting the engine, gearbox etc almost free, and i just wanna know if it would be more trouble than it's worth.
Thanks, Chris
Posted on: 2003/8/8 15:39
Re: L series conversion
From Millgrove Vic OZ
A good N/A L18 will put out 170-190 hp with a lot of work or an easy 130 hp.
The only disadvantage with the swap is the heavier engine causes understeer.
Compare this with the : -
nimble , efficient , powerful , responsive , light , good looking , environmentaly responsible , economical , smooth , A series engine and you can see where my allegiance lies
Posted on: 2003/8/8 23:35
Cheers Feral
From California
I just can't understand why nobody has gone all the way and spliced a Sunny Excellent front clip to their ute.
When you're done, you could call it the "Excellute."
Posted on: 2003/8/9 1:53
From NorCalifornia, up by Sac
Hey Feral, of the A's, what is your fav setup?
Posted on: 2003/8/9 2:20
Excellute idea!
Posted on: 2003/8/9 3:32
From Christchurch, New Zealand
[quote="feral"]Powerful...smooth
Arnt these too kinda mutually exclusive. Sure you can have one or the other but its pretty hard to have both with an A-Series ;)
Posted on: 2003/8/9 5:17
Quite a regular
Also, 2 other things
1) will the l18 4 speed (out of 720 ute) fit in my 1200 ute tunnel (manual) without modification?
2) Will i need to change the standard 1200 diff? will it handle the upgrade in power?
Thanks for your responses
Chris
Posted on: 2003/8/9 5:46
From Mudgee NSW Australia
I have seen L18 fitted into a 120Y it fitted quite nicley they are a pretty tall engine and heavy compared to A series . In my opinion you would be better of with a A15 worked over as errol says they have lots going for them :)
The gearbox should fit in the ute tunnel you will still have to remove the standard mounts as they protrude into the tunnel the A series box is quite thin the L series is a little on the fat side.
The standard ute diff can handle a fair amount of power I would keep it just dont give it too hard a time or lock the center as axles will break.
Cheers Andrew
Posted on: 2003/8/9 11:03
If In doubt run more BOOST
NO,
My favourite A setup is :-
Dry sumped A13 with titanium rods, short compression height forgies with 1 mm, 1mm, 2.8 mm oil rings. Late A14 NISMO head with stainless 40 inlets, 37 exhausts high ported with Yella Terra 1.6 ratio rockers .
45mm Motec throttle bodies Autronic SMC (Autotune) ECU. Sand bent Facey headers and exhaust. Apart from the dry sump and roller rockers its what I have now. I am saving my hard earneds to buy a set of roller rockers and the dry sump pump and bits at the moment.
$2800 to go
I love it when older technology can beat later hitech (but not as highly developed) vehicles. Makes life worth while
I am building an A15 grunter at the moment for a bit of fun and am using the Nismo head on that, to see what it will do on a big block
Posted on: 2003/8/9 13:54
Cheers Feral
From Brisbane
Errrrreeeee hereeee, great comment!
Posted on: 2003/8/9 14:07
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
