#1 Ignition Coil Question
matty Posted on: 2009/4/13 0:03
I have recently bought a Bosch GT40R coil.
I am also about to purchase a Pertronix electronic ignition kit.
Will the GT40R coil work with the electronic ignition?
Cheers Matty
#2 Re: Ignition Coil Question
dattodude Posted on: 2009/4/13 0:42
Interesting Pertronix reading:
http://www.viczcar.com/forum/index.php?topic=2784.0
Interesting Bosch Coil reading:
http://apps.bosch.com.au/motorsport/downloads/ignitioncoils.pdf
So the GT40R is a 1.2 Ohm coil (1.5 Ohms recommended by Pertronix?)
Maybe the GT40RT might have been a better option.
I'd probably drop an email/call to the pertronix people.
#3 Re: Ignition Coil Question
matty Posted on: 2009/4/13 10:13
Cheers Chris
Email sent to Pertronix.
Do you know what a difference of .3 OHM might mean to performance and longevity?
#4 Re: Ignition Coil Question
ddgonzal Posted on: 2009/4/14 3:42
Yes, lower Ohms draws more amps, which could cause the Pertronix to burn up. It depends on how much amps the Pertronix can handle.
