« 1 (2)
Re: 1200 deluxe distributor ignitor? Zimbabwe
Quite a regular
From pretoria, south africa
hey ethen, you should look if its getting fuel... i had the same prob kinda except the pipes comming out of the fuel float bowl so that it doesnt vacume were blocked... if you you clean them out it might sort out that prob... or it has to do with the fuel lines and breathers by the tank i had a problem where it vacumed there.. but try those pipes.. if you understand what i`m saying
Posted on: 2009/3/24 16:02
Quite a regular
i meant the breathers for the fuel bowls on the carbs... when the air cant come out it stops the fuel comming through... you`d see if you had to open it that the fuel will fall into it when it gets air... so just check that out.. cause it also doesnt fire when its not getting fuel XD
Posted on: 2009/3/24 16:08
1200 running like a tractor - sometimes...
Like a Lamborghini tractor? Or like a Ford tractor?
Posted on: 2009/3/27 1:58
Re: 1200 running like a tractor - sometimes...
From Harare, Zimbabwe
guess what.... i changed my coil & the problem is not as bad anymore! so i think it was the coil among other things... i think my engine needs some TLC...
Posted on: 2009/4/16 9:25
"Make a plan!!!"
From Cape Town, South Africa
Try another set of spark leads, had a issue like that 2 weeks ago, replaced the coil and all, was better, but after a lead change the old toyota was running like a new one.
Posted on: 2009/4/24 12:43
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
Ethan, glad to hear it is now fixed. How much does petrol cost in ZW now? 4 liters is one hour's wage?
Posted on: 2009/4/25 6:57
petrol is 105 US cents per ltr now, so thats US$1.05. diesel is stil at 85cents.
as to the hourly wage equiv - it depends on the job hey...
I earn more than that at the mo, but then, i'm a consultant - not full time employed.
Posted on: 2009/4/27 10:31
« 1 (2)
