Some Component Weights - in case you were curious
From Las Vegas USA
As I mentioned in another thread I took some weight out of the Coupe. So for anyone with a track only car this maybe of use.
Rear Bunper 8.4 lbs (exactly what the FIA spec on the site says)
Door Window 5 lbs
Door Mech 2 lbs
Side Window 5 lbs
Headlights/side marker lights/headlight buckets/turn signals 6.2 lbs
Horn .2lbs
Front Bumper 4.5lbs (this was w/out brackets and it was a modded bumper)
Modified Flywheel per drawing on this site does weigh 14lbs (saves 7 lbs)
I did keep track of sound damping material removed for the cage install and I managed to take out 6 lbs worth
There is also about 4lbs of misc brakets that can be cut off ( jack holder part in the trunk etc.)
When I have a chance I'll list some others.
Tom
Posted on: 2009/4/19 18:01
