CA18DET Fuel Pressure Regulator Question
From Mandurah, Western Australia
I believe my CA to be running to rich as it has excessive soot in tailpipe, and excessive black smoke.
I have a Goss motor sport fuel pump which is quite large (Equivalent to Bosch 044)and Im running the stock Fuel Pressure Regulator. Is it possible that the stock FPR can not cope with the pressure from this pump?
Should I run a Aftermarket FPR before the input to the fuel rail and leave the stock unit in place?
If I need a FPR is one of the $100 units on Ebay OK?
The Engine and Management is Stock
Cheers
Posted on: 2009/4/22 10:50
Re: CA18DET Fuel Pressure Regulator Question
sounds normal man stock ecu runs pretty rich i used to have black s*** all over the tail gate, get a pressure gauge n just check it if you've got doubts
Posted on: 2009/4/22 12:30
From Brisbane
Now I might be talking about the same car as Leith... But yeah mine runs pretty rich, and blows black when you first give it some. Have had it on the dyno and it runs rich down low but is ok when you right up it...
Posted on: 2009/4/22 13:19
If you want more inches, stroke it
