Are axles the same?
From Oberon NSW {Bathurst}
Hi All, I just swapped out my H145 for a H150. I was wondering wether to keep the 145 axles if they are the same as the 150's. I don't wan't to pull the old diff down if I can't use the parts. I'll just send it to the dump in one piece, less mess thet way! Cheers.
Posted on: 2009/4/25 14:28
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
Re: Are axles the same?
From newcastle, NSW
i think that the axels are the same. I know that you can put the H150 into a H145 housing, all you need is a 2-3mm spacer,so i would assume that they are the same. The axel tubes are slightly larger but i think that two diffs are the same width. The only way to find out is to pull them both apart and compare them.
Posted on: 2009/4/25 15:04
Yes, same part number:
* 38162-G0300 ASSY-SHAFT REAR AXLE
B110 with H145
B210 with H145
B210 with H150
B310 is different. H165 is different
Posted on: 2009/4/25 21:32
Edited by ddgonzal on 2009/4/25 21:55:48
From Christchurch NZ
are you sure that the b310's use a different axle? Different in legth perhaps, but I think the spline is the same.
Posted on: 2009/4/25 23:28
Forced Induction!
The part number is different, that's all I know.
Posted on: 2009/4/26 0:07
