Re: f/s 15in simmons
outer fron or rear edge? also what is it from the other way then aswell as both are needed for offset (also 495mm? seem pretty extreme ... lol)
http://www.rims-n-tires.com/rt_specs.jsp need to be exact as it makes a big difference to my aplication
yfj20t wrote:
hay datsun1000 and anyone else thats interested from hub face to outer rim edge is 495mm or just shy of 5in
Posted on: 2009/4/28 11:54
From Sydney
whats the backspace figure? Most if our datsuns fit rims with 90mm - 125mm backspace. e.g 15 X 6 with 120mm backspace will sit nicely under the std 1200 guards
Posted on: 2009/4/28 12:20
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Bathurst - NSW
From the "just shy of 5" figure" i would understand the backspace to be 120mm.
Posted on: 2009/4/28 12:38
From canberra
sorry all 124mm so it is et36
Posted on: 2009/4/29 11:01
need to move your ride
tuggeranong towing call 0421towing
0421869464
cheers! too bigger offset for my needs
Posted on: 2009/4/29 11:35
From canberra
bump
Posted on: 2009/5/5 9:12
0421869464
From canberra
ok best genuine offer gets them
Posted on: 2009/5/6 8:20
0421869464
Re: f/s 15in simmons best offer
From Mackay QLD
so all 4 wheels are the same offset?
Posted on: 2009/5/7 8:03
From canberra
yep
Posted on: 2009/5/7 9:17
0421869464
From canberra
bump
Posted on: 2009/5/15 23:07
0421869464
« 1 (2) 3 »
