Re: Is it worth a try?
120y eith l series is pretty straight forward, either mod the existing x member for the l series mounts or use a 180 x member but it mucks up your steering gemometry a bit (ask rev head).
You will need a auto tail shft for the conversion so buy an auto 120y if you can, and use the 1600 5 speeds or 4 speeds (stumpy) and should bolt in easily enough for you.
Tunnel is ok in 120y for the L series as same for auto or manual.
Posted on: 2009/4/29 5:11
Subject Poster Date
     Is it worth a try? pk75 2009/4/28 9:47
       Re: Is it worth a try? ddgonzal 2009/4/29 3:56
       Re: Is it worth a try? Anonymous 2009/4/29 5:11
       Re: Is it worth a try? pk75 2009/4/29 7:46
