#1 Wanted: Water Pump & Bolts for L16,L18,L20 or L20B
Igneous Posted on: 2003/8/13 20:47
HI,
I am looking to Purchase a Water Pump
and THE FIVE (5 Ea.) Mounting Bolts for a
Datsun: L16, L18, L20 or L20B engine.
igneous@sprintmail.com
#2 Re: Wanted: Water Pump & Bolts for L16,L18,L20 or L20B
rgrinder Posted on: 2003/8/14 9:17
which one???????
that I know of, there are 4 different L series water pumps.
also, WHERE ARE YOU??????????
#3 Re: Re #2: Wanted: Water Pump & Bolts for L16,L18,L20 or L20B
Igneous Posted on: 2003/8/17 18:21
Hi,
Thank's for replying.
I am currently running an L20B Engine... What I Really NEED Are The BOLTS !!!
I know it sounds strange, but heres the story:
I recently had a timing chain replaced, and soon after discovered a leak. Turns Out They Didn't Put ALL The Water Pump Bolts BACK. I Particularly need the LONGEST BOLT... you know, the one on the right side of the engine. She runs like a champ and purrs like a kitten, but leaks like a spaghetti strainer. Bolt Tightening and/or form-a-gasket aint fixing this problem...
I need a new set of water pump bolts! I imagine a set of bolts from any of the mentioned engines will do. I have NOTHING To LOSE BY TRYING.
I am in New York, New York
HELP !!!!!
#4 Re: Re #2: Wanted: Water Pump & Bolts for L16,L18,L20 or L20B
matbighat Posted on: 2003/8/18 1:39
Because newbies often leave the location setting blank, Pedro and Daniel might want to make it mandatory.
#5 Re: Re #2: Wanted: Water Pump & Bolts for L16,L18,L20 or L20B
rgrinder Posted on: 2003/8/18 2:46
I second that!!!!!!
for your bolt(s) go to a local supply house and ask for them the one you are looking for should be 8mmx5 in.
either that or go to a dealer and ask them to order you some.
