Howdy,
I have a locked diff in my 1200 coupe sports sedan
and would give it up in a heart beat if I could get a
ATB LSD centre for my H165 diff.
with the locker I don't dare go near any ripple strips
as they up set the rear drive so much with the locker.
at speed, the under steer into corners is exagerated with the locker also. I tend not to power in and turn at the same time.
it's almost like you can only do one thing at a time with a locker.
eg can't brake and turn
can't turn and power (tight)
trail braking works the best, but can go
very wrong very quickly.
my answer to a locker in a street car . . . . .
bad idea.
Some one mentioned earlier in this thread about the
V8 supercars running a spool diff. Yes they do, the rules were changed in 1998 (class started in 1994)as a cost cutting measure due to the large amounts of money that was being spent on LSD's that would handle 550hp. (now upto 650hp).
the handeling side of things was not taken into consideration. it was all about cost and evening up the playing field.
if they could run LSD's they would.
They spend the big money now on shocks and shock dynos.
So does anyone know where I can get an ATB LSD for my H165 diff?
Cheers,
Geoff
