WTB: Turn signal Cam
From Vancouver, Wa
I need to buy or trade for a turn signal set up ASAP!! I need the part that controls the blinkers and the high beams. The whole assembly that goes around the steering conlumn. Mine is shorting out and won't allow my low beams to stay on unless I hold it in place or I HAVE to drive with my high beams
Posted on: 2009/5/12 6:03
Re: WTB: Turn signal Cam
Quite a regular
From California,USA
I have several used complete units, and one or two in pieces. UPS Ground in approx 1-2 days.
Stainless trim???
How close to Bothell are you?
Posted on: 2009/5/12 6:20
From Vancouver, Wa
Is there a difference between the Sedan and Coupe turn signal Cams?
Posted on: 2009/5/12 6:30
Quite a regular
From California,USA
No difference in coupe vs. sedan, in US form.
Right hand drive vs. Left, might be another story.
Do you have a rear window defroster in your car?
Posted on: 2009/5/12 6:56
From Vancouver, Wa
Our cars came with a rear defroster!! Oh the answer is no lol it does'nt
Posted on: 2009/5/12 7:00
Quite a regular
From California,USA
Some did
Check PM
Posted on: 2009/5/12 7:06
Remove the upper and lower plastic column cover. Then tighten the two screws fixing the T/S assembly to the column. That may fix it, it fixed mine.
Posted on: 2009/5/12 7:15
From Vancouver, Wa
No die Ddgonzal it is still messing up
Posted on: 2009/5/12 8:48
