Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Forged conrods for A15
datster
Posted on: 2009/5/15 14:32
Where do we get forged conrods for the mighty A15 I spoke to the guys at Paeco and they want like US$1450 I mean the motor didn't even cost me that much.The reason I want forgies is because I will be running forged pistons.Any help is greatly appreciated.
#2
Re: Forged conrods for A15
LittleFireyOne
Posted on: 2009/5/15 17:05
![]() That's a CA18 forged rod sitting with an A14 rod, worth some more investigation since A14 and A15 share the same conrods, it's just the piston pin height and crank that differ. Thread for teh pic : Rods forged in FIRE!01101101!!!!!
#3
revhead001
Posted on: 2009/5/16 1:44
Orger Engines in Bayswater can make you any conrod in any dimention that you want for about $500 each. Then you can offset grind a crank and do whatever piston / conrod combo that you want!!
#4
D
Posted on: 2009/5/16 1:52
For A14/A15 tall blocks 204.1mm
Cheap rods with great clearance for strokers with 136.62 (E16/E15et) and 140.462mm (E15) in length are Nissan E series rods. These are an alternative if you get the crankpins machined and retreated from 48mm(is that right on A series cant remember?) to suit 40mm at the same time you can play with the stroke or move the centre 8mm after tdc like modern toyota and other engines using max power of the powerstroke, downward angle and less friction for low rod/stroke ratios like used in hondas, nissan and everyone else these days. ![]() E15 and E16/E15ET rods, 140.64mm and 136.62mm respectively Look how much clearance they would have in a stroker!!!!!! Also how beef they are but small big end to reduce friction and overall weight.
#5
D
Posted on: 2009/5/16 3:43
For A12 short blocks 189.1mm?
Hayabusa Conrods are a nice option and here is a chart I compiled. CONROD + CRANKSHAFT Unit: mm (in) Conrod small end I.D. STD/SPEC: 20.010 – 20.018 (0.7878 – 0.7881), LIMIT - 20.040 (0.7890) Conrod big end side clearance STD/SPEC: 0.10 – 0.20 (0.004 – 0.008) LIMIT - 0.30 (0.012) Conrod big end width STD/SPEC: 20.95 – 21.00 (0.825 – 0.827) Crank pin width STD/SPEC: 21.10 – 21.15, (0.831 – 0.833) Conrod big end oil clearance STD/SPEC: 0.032 – 0.056 (0.0013 – 0.0022) LIMIT: 0.080 (0.0031) Crank pin O.D. STD/SPEC: 37.976 – 38.000 (1.4951 – 1.4960) Length for the Hayabusa I think is 119.500mm big end and small end width 20.975mm G/pin diameter is 20mm 38mm crankpins (means 10mm stroke possible or 10mm offset crank centre just by offset grinding) The Suzuki TL1000R conrod is: 122.9868mm is a better size but cant find specs
#6
Posted on: 2009/5/16 4:47
Why not just use the stock A-series forged conrods?
#7
datster
Posted on: 2009/5/18 12:13
Okay guys so if I get my hands on some CA18 forged conrod all I have to modify is the small end from what I have read????????Also the reason I want forged rods is that from what I have read on the site about the forged rods is that they are stronger and lighter than the stock items.I have lightened the fly wheel and crank a good deal so I would rest easier with forged rods.
#8
D
Posted on: 2009/5/18 14:17
the reason i was suggesting the stronger rods from e15et or e15
for turbo and hayabusa rods for NA setups is because they are superior.
#9
datster
Posted on: 2009/5/18 14:58
My motor is normally aspirated so from what you are saying I should use the Hiyabusa rods.Why are they superior to after market CA rods????????From the photo that has been posted of the CA rod with the A14 rod on top of it looks very close in terms of size.
#10
D
Posted on: 2009/5/19 1:26
Weight is the key, standard datsun A series rods are lighter than billets
H beam and many others. The Hayabusa rod is suited for a short deck a12 not really an a14/15. The hayabusa rods dimensions allow you to run smaller offset crankpin for more stroke or offset crank centreline. Do as DD said and save youself a fortune and run standard worked rods or if you want to rev higher then the e15et rods with modded crankpins will they give higher rod stroke ratio and 7mm offset crankshaft centreline for better power usage as the rod is already past crank centreline where longer rod combos have difficulty in speed. Do some research and dont spend big money on what is not needed, in your case a heavier rod that makes no more power. Have a look at some past links youll see standard cast mazda pistons and other makes work very well with stock rods. Its all in the work and finish done to your internals, speedway people and other datsun racers know this. I suggest the e15et rods as they are 3.5mm longer, have smaller cranpin which is essential to make extra power, have less weight for material and strength of rod, allow stroking/destroking and offset crank centerline as mentioned. Also cheap as chips. You can view topic.
