#1 Cylinder oiling/passage question
Rallytwit Posted on: 2003/8/19 18:47
Ok I was looking at the H-production head as Nismo calls it and noticed a hole plugged that wasn't plugged on the GX head. The hole is on the manifold side in between #2 and # 3 combustion chambers. It is about 3 mm in diameter looks like an oil gallery. If I bolt the H-prod head on the GX block do you need top drill out this hole??? can the whole be drilled???
Tom
#2 Re: Cylinder oiling/passage question
AFRacer Posted on: 2003/8/19 23:57
I believe this hole is for coolant through the intake manifold. All the stock GX (SU) intake manifolds had water/coolant circulating through the intake. I guess it's supposed to help regulate temps, but I always thought it would heat the intake up too much. You should be able to tap and plug this hole. Pictures would help give a positive identification of what this hole exactly is though.
#3 Re: Cylinder oiling/passage question
ddgonzal Posted on: 2003/8/20 5:27
A12 GX Head
This one only has the intake water holes under two of the intake ports:
#4 Re: Cylinder oiling/passage question
ddgonzal Posted on: 2003/8/20 5:34
Or do you mean it is on the combustion face? There's as small one here between 2 and 3:
Here's the matching hole on the A12 block:
#5 Re: Cylinder oiling/passage question
Rallytwit Posted on: 2003/8/20 17:17
I do indeed mean the face. Duuhh should have mentuioned this. After looking at it last night it appears to be a cooling passage. Question still is does this need to be drilled out to match the deck on the GX block???
Tom
#6 Re: Cylinder oiling/passage question
ddgonzal Posted on: 2003/8/20 20:59
Can you post a picture of your cyl. head showing the passageway you are referring to?
Not sure if this will help, but check out Info required re A12 Gx Head
