Re: efi
Quite a regular
any idea of cost and where to buy in adelaide thing is i have the next model up 87 pulsar out the back i think n13'have comp,injectors,ra,ra
just read in wiki u can use previous model dizzy and changing the drive to a14 or is it better, easier to go e15?
cheers
Posted on: 2009/5/17 14:22
Re: efi
Not too shy to talk
From Craigmore, SA
Sorry, i dont have any photos with me, next time im back home in SA, ill grab a couple.
when we used the camira gear, we used a weber manifold, and had some injector bosses welded into it, then made a plenum, i think we used a SR throttle body from memory.
If you allready have a donor car, then really the only costs are getting a manifold sorted out, throttle cable and surge tank/efi pump setup.
Posted on: 2009/5/18 1:43
Re: efi
Quite a regular
cheers big ears
Posted on: 2009/5/18 1:59
Re: efi
Quite a regular
just saw the efi set in in photos a15efi nice
how did this set up go ,did you make it this, one photo answers quite alot
Posted on: 2009/5/18 2:11
Re: efi
Quite a regular
yeah no probs with fabricating the manifold can do all that mainly just electric dizzy and the comp stuff have absolutely no idea is yer mate in adelaide? and stuff like efi needn pressurized fuel do u just run electric pump and return line ra ra
cheers 4ya time
Posted on: 2009/5/18 4:10
« 1 (2)
