Re: beefy a14 build with keihin 40.60 mm carbs.
Quite a regular
From Modesto, CA USA
got the car finally running and idling. its a pain in the ass to sync the carbs. When i drive it its bogs alot wont pull at all i think im getting lean pops. considering the carbs are from a 1100cc street bike.. i have a a14 with a nice cam and big ports with 10.4 :1 compression. Anyone have any ideas on getting it to get more fuel. i been reading about different needles. Shimming needles, different jets. Also gonna adjust floats. thanks
Posted on: 2009/5/18 6:45
Daft Innovations
For ls1 swap parts for 240sx
Add me on Myspace For swap pictures.
From Melbourne, Oz
got to a motorcycle mechanic and they can plug there meteringequipment in and sort it out.
Posted on: 2009/5/18 6:51
"I hav achieved wood"
They like to be gravity fed. I have changed the spring in my fuel pump to drop the pressure.
Perhaps there is too much pressure.
Fair enough you have bigger capacity etc but do the bike engines pull alot more air? Higher rpm etc?
Posted on: 2009/5/18 6:53
Quite a regular
as far as syncing them I will use that one redline sells for syncing sidedrafts I think that will work for me. motorcycle mechanics normally tap into each runner. problem is I don't have vacum source on each runner. also I thought it would be enough fuel but I know its running lean it has to be. I running stock a14 mechanical fuel pump. when I hold choke on or cover part of carb intake it will rev .nicer ... getting to much air for the small amount of fuel. 1100 cc each cylinder is 275cc on a a14 is more then 350 cc per cynlinder.
Posted on: 2009/5/18 7:52
Daft Innovations
From Southern Highlands, NSW, Australia
I had to drill the main jets out heaps to get a decent a/f ratio in the top end. I packed 4 or 5 fibre washers under the needles to lift them up as well. As for synchronising the carbies I used a piece of mig wire as a feeler gauge to set the throttle butterflies the same and tuned the idle screws by ear, listening to the revs rise and fall. It ran well once it was sorted. Your fuel pump should be fine, I ran 6 psi of fuel pressure with a facet pump with no dramas.
Posted on: 2009/5/18 9:32
'72 1200 sedan hillclimb/supersprint car
Quite a regular
Nice man.. thanks for info. btw i pinched the rubber velocity stacks to reduce air flow and car ran alot better but still no top end. i need to break motor in anyways got about 40 miles on it now. I need to find washers to fit the needle cup thing with spring. sounds like i will get this setup running. The main is the jet that sits into the float bowl right.
Posted on: 2009/5/18 18:46
Daft Innovations
Quite a regular
Ok i took out the jets cleaned the carbs and the mains said 160 on it. i drilled it with a 1.85 mm so 185 and the car is like night and day still havnt tached it over 4500. runs titi-lisious so far. Will dial it in a little better.
Posted on: 2009/5/18 23:33
Daft Innovations
Quite a regular
just took car out for 100 miles break in with 95 degree weather. ran good. Pulled it up to about 7500 with good power. i need to sync the carbs still it pops every once in a while. what would shiming the needle do for me ?
Posted on: 2009/5/19 2:18
Daft Innovations
Quite a regular
Youtube video of todays runs.
http://www.youtube.com/watch?v=EJl_-sxBK9Y
first gear i could have reved it out a bit more but didn't motor only had 150 miles on it . cast rings i used so they should have seated in first 100 miles i would think.
http://www.youtube.com/watch?v=rrfNLltdT_4&feature=channel_page
Posted on: 2009/5/19 7:17
Edited by daftinnovations on 2009/5/19 7:39:18
Daft Innovations
From Melbourne, Oz
Dude that sounds mean! I am so geting some kahinies!
Posted on: 2009/5/19 8:49
« 1 2 (3) 4 »
