Browsing this Thread:
1 Anonymous Users
Turbo project |
Hi all, I have just bought a suck through turbo setup to suit an oval port head A series engine. It has an SU carb mounted on an IHI RB6 turbo, this turbo was originally off a 2Litre mitsubishi galant, and it has been rebuilt and modified so it now has garret internals. I plan to put this setup in my 1000 coupe,but i think this turbo is too big to put on the A10 i have at the moment. So I'd like to build an engine to suit this setup, either an A14 or A15 bottom end, with an oval port head. I'd like to know if E15 turbo pulsar pistons (and rods) can be made to fit an A14/15 block. Also I'd like to find out engine specs for A series engines, things like bore,stroke, volume of combustion chambers, standard compression ratios,etc. thanks, James
Posted on: 2001/3/12 11:02
Re: Turbo project |
From Sydney
Registered Users Contentmaster
Heya James, i have some A series engine specs that u asked for. Standard bore for A10/12/13 is 73mm Standard bore for A14/15 is 76mm Standard bore for A12A is 75mm A10 Crank is 59mm A12/A12A crank is 70mm A13/14 crank is 77mm A15 crank is 82mm A10 Conrod is 117mm A12/A12A conrod is 121.5mm A13/14/15 conrod is 133mm CC for A10 is 987.8cc CC for A12 is 1172cc CC for A12A is 1237cc CC for A13 is 1289cc CC for A14 is 1397cc CC for A15 is 1488cc Block height for A12/A12A is 189.1mm Block height for A13/14/15 is 204.1mm CC for GX type head is 29cc CC for A12 type head is 27.5cc Max bore for A13/14/15 is 79.5 - 140thou over Max CC for an A series 1628cc using A15 crank and 140thou over. As u can see i've done my homwork on the A series! But i dont have a clue about the E15 engine but could be worth looking up for future projects!! Hope this helps for what u are looking for. Scott Davo
Posted on: 2001/3/15 4:21
