mix and match tail shafts
From illawarra, nsw australia
hello
i have nearly pieced together all the parts for the auto-man conversion in the y
the only thing holding me back is tailshaft
im running a borg warner rear and it just so happens that tail shafts to fit manual are becoming hard to find
now to my understanding the u joints cant be taken apart and fittings,flanges interchanged etc,
can this be confirmed?
the reason i ask is because i have an auto, BW tailshaft and have access to manual, JAP tailshaft
i have access to a few diferent tailshafts to fit early corollas, coronas etc running bor warner rear but just cant seem to find what im after
any information goes a long way and is greatly appreciated
Cheers
Jason
Posted on: 2009/5/22 14:25
Re: mix and match tail shafts
Naw it doesn't work that way. With some shafts, a driveshaft shop may be able to cut and weld the parts, then rebalance the assembly. But with many shafts this is not even possible.
Posted on: 2009/5/22 19:17
From Brisbane
Yeah you can get a whole new tail shaft made up for around $500. My tail shaft in my ute had non replaceable uni's so i just got one made up. If you end up doing a uni joint id have to make a whole new shaft anyways... So was better off just makin a new one. And yeah they have to be balanced or it could get real out of hand
Posted on: 2009/5/23 4:29
If you want more inches, stroke it
From NZ
I run a Ford diff (blasphemy I know!) in my racecar - was the best way to get ratios and LSD at the time. "English" type and in my case from a Mk2 Cortina - I think it has the smaller diametre flange vs say Ford Escort? Sunny B310 driveshaft / flange bolts up with no modification at all.
Posted on: 2009/5/23 10:32
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
From Armidale N.S.W
Wow Guess what ? We have a 120y manual tail shaft for Borg Warner here and it so happens i am after an Auto one wanna swap me ? You send yours i send mine to easy campese.
Posted on: 2009/5/23 11:56
73 1200 wagon SOLD
guys
gotta just say thanks for all the information
Jason
Posted on: 2009/5/23 12:16
