Wanted to Buy- Weber 32/36 choke linkage
From Bathurst - NSW
I have a 32/36 that has the choke butterflies in place but no form of linkage for me to connect my manual choke to. I'm after an electric/water/manual choke setup that someone has that they no longer require, so that i can modify it to suit. Thanks
Posted on: 2009/5/23 6:12
Edited by BRUTE on 2009/5/24 12:00:58
Re: Wanted to Buy- Weber 32/36 choke linkage
From Bathurst - NSW
bump
Posted on: 2009/5/24 12:01
From Melbourne, Aus
I have just fitted one of these carbies to my a15.
The previous owner of the carb had taken the choke butterflies out.
It doesn't seem to need it, as it starts and runs fine without it.
have you tried running it without the choke?
cheers
Bruce
Posted on: 2009/5/27 5:53
From Snohomish, WA USA
This is very true. I removed both my chokes. Try it without the choke. You may be surprised.
Posted on: 2009/5/27 6:53
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Yes, if you consider having to foot the throttle first few minutes as 'running fine'. I prefer to pump the pedal, twist the key and let it run itself.
My twin-sidedrafts have no choke. It starts OK. In cold weather I have to pump it extra. If I give it enough throttle it'll start up and not die. Too much throttle, whoops, don't want to rev it over 2000 RPM for the first 10 seconds...
32/36 doesn't need linkage for electric choke. Just remove the water choke, and put a Datsun, Ford or Weber electric choke (un-modified) on it. Wire it to the coil. Done.
Posted on: 2009/5/27 7:33
From Bathurst - NSW
I'm in Bathurst NSW so -5 degrees celcius is about to become the norm in the morning, me thinks i will be needing the choke. I have tried life without it, tried a few squirts of aerostart to kick things into gear, works well but why would i do that every morning.
The choke plates are in the carby, i just have no mechanism in place to actually control them, ie no linkage from the choke shaft to connect the choke cable to.
Still looking for something
Posted on: 2009/5/27 10:06
From bathurst nsw
what about adapting a setup off an xd-xe 6 cylinder falcon weber? is that what you are after, it runs off coolant temp from memory, if your getting stuck for winter you could allways borrow my one off my weber, (i think its mechanical but ill have to double check) because im in the middle of painting the 1200 its on, and it wont be done for a while yet, definatly not through winter. that would do until you found one
cheers kurt
Posted on: 2009/5/27 10:24
My car gets me from A to B...Just faster ;)
From Bathurst - NSW
I might just have to drop around and see you Kurt.
Posted on: 2009/5/27 10:32
From hastings,vic
might have a manual linkage at work
will check tomorrow
tommo
Posted on: 2009/5/27 10:45
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From bathurst nsw
i just went down and checked sam, and unfortunatly i dont even have any form of choke on mine either, sorry i thought it did. if you dont end up finding anything maybe we could both look into converting the falcon setup, even if it is a pain in the a$$ of a setup.
Posted on: 2009/5/27 10:55
