Re: Correct firing position of No 1 distributor Lead on an A15
From Brisbane, Australia
Thanks DD, what your saying is what I've been seeing, the same results in all four positions. Wants to start but just not enough spark I guess. Have swapped everything, coil, leads, points, plugs, caps, buttons. Moved dizzy while cranking and kicks back sharply when retarted. Its definitly got plenty of compression, Carbs are getting fuel but I don't know much about hitachi's, but am told not much usually can go wrong with them.
Any ideas anyone???
Thanks
Geoff
Posted on: 2009/5/23 23:34
Subject Poster Date
     Correct firing position of No 1 distributor Lead on an A15 DatsunRepairSquad 2009/5/23 12:00
       Re: Correct firing position of No 1 distributor Lead on an A15 ROConnor 2009/5/23 15:04
         Re: Correct firing position of No 1 distributor Lead on an A15 ddgonzal 2009/5/23 19:40
       Re: Correct firing position of No 1 distributor Lead on an A15 DatsunRepairSquad 2009/5/23 23:34
         Re: Correct firing position of No 1 distributor Lead on an A15 ddgonzal 2009/5/24 1:40
       Re: Correct firing position of No 1 distributor Lead on an A15 DatsunRepairSquad 2009/5/24 3:39
         Re: Correct firing position of No 1 distributor Lead on an A15 clyons8 2009/5/24 5:15
           Re: Correct firing position of No 1 distributor Lead on an A15 Mildman 2009/5/24 6:05
       Re: Correct firing position of No 1 distributor Lead on an A15 DatsunRepairSquad 2009/5/24 6:31
       Re: Correct firing position of No 1 distributor Lead on an A15 DatsunRepairSquad 2009/5/24 7:19
