Re: s13 struts
From Burpengary
Dazza, nah mate, I can tell that! The problem is, I bought a set of (what I thought to be) R31 Radius rods off a member on here and they are 371 (ish) mm from the more forward hole to the beginning of the thread. The datsun 1200 ones are about 320mm.
My understanding was that the r31 parts should be shorter? is this correct? currently they do not fit and will need to be modified to be an appropriate length.
The reason I ask is because, if (and I do mean if!) I have been sold the wrong part then oh well, I will buy the correct part. I just want to know if the rod I have is supposed to be modified to fit or if it is simply wrong.
Posted on: 2009/1/26 7:14
Re: s13 struts
From Burpengary
and Thanks Frank, those number might come in handy
Posted on: 2009/1/26 7:37
Re: s13 struts
can we get in one post a parts list of whats needed to have s13 coilovers on a 1200 =] plz plz plz
Posted on: 2009/1/28 9:59
Re: s13 struts
From Brisvegas, oz
s13 struts cut down with coilovers fitted.
s13 lower control arms
s13 outer tie rods (standard tie rod link needs rethreading to suit)
r31 radius rods
s13 knuckles
any brakes that fit the s13 eg s13, r32 ect ect
Posted on: 2009/1/28 10:19
www.camerasplus.com.au
Re: s13 struts
From hobart tas
how much did you have to shorten your struts? Do you think you can get away with aftermarket s13 coilovers and wind them down
Posted on: 2009/2/28 6:21
Re: s13 struts
From Townsville, Qld
Jake 77 went that way and from what I read of it he didn't have issues
Posted on: 2009/2/28 16:10
Re: s13 struts
u can fix s13 sturut ( must be adjustable ) im using it right now using
1.s13 disc n knuckle
2.lower arm
3.tierod end @ ball joint
but the steering will be heavy..
Posted on: 2009/4/27 6:06
Re: s13 struts
Not too shy to talk
From Rockhampton Qld
Got S13 rims [+40 offset] on 120y strut with 1600 hubs + s13 discs = 12mm increase in track ,ie still legal & light weight.
Posted on: 2009/5/25 11:16
1200 ute ca18det [in build] , XR6T 314 RKW , FXSTF tractor.
Re: s13 struts
My friend Nathan has just done this conversion to his R30, he found he has lost a a fair bit of steering lock. He'll fix that but what's other peoples experience with this issue?
Posted on: 2009/5/26 1:40
Edited by littledarkone on 2009/7/27 5:35:52
« 1 2 3 4 (5)
