Re: killer a14 turbo motor build up
From hervey bay queensland
im simply saying that any motor highly modded with a turbo that is pushed to its limits at 25psi you will have reliability problems it may only be little things like gaskets blowing but to me that means reliability problems , maybe putting a dual stage boost controller on would be a good idea so you can run say 14psi normal driving then when you realy wont to get under it you can go up to your 20-25psi, and you wont be putting so much unneeded strain on the motor during normal driving.
maso
Posted on: 2009/5/26 23:40
classic not plastic
Subject Poster Date
     killer a14 turbo motor build up datto1000wagon 2009/5/25 13:33
       Re: killer a14 turbo motor build up clyons8 2009/5/25 14:02
         Re: killer a14 turbo motor build up Dundee1000 2009/5/25 15:25
       Re: killer a14 turbo motor build up luis12 2009/5/25 20:28
         Re: killer a14 turbo motor build up luis12 2009/5/25 20:30
           Re: killer a14 turbo motor build up datto1000wagon 2009/5/25 21:49
             Re: killer a14 turbo motor build up steveo 2009/5/26 2:29
       Re: killer a14 turbo motor build up D 2009/5/26 2:04
       Re: killer a14 turbo motor build up maso-13 2009/5/26 2:42
         Re: killer a14 turbo motor build up steveo 2009/5/26 11:57
           Re: killer a14 turbo motor build up datto1000wagon 2009/5/26 12:17
             Re: killer a14 turbo motor build up Ianey 2009/5/26 13:36
       Re: killer a14 turbo motor build up D 2009/5/26 15:22
       Re: killer a14 turbo motor build up clyons8 2009/5/26 21:22
         Re: killer a14 turbo motor build up nick_m 2009/5/26 22:57
       Re: killer a14 turbo motor build up maso-13 2009/5/26 23:40
         Re: killer a14 turbo motor build up datto1000wagon 2009/5/27 0:27
       Re: killer a14 turbo motor build up maso-13 2009/5/27 1:44
       Re: killer a14 turbo motor build up broccoli 2009/5/27 3:57
       Re: killer a14 turbo motor build up D 2009/5/27 5:25
         Re: killer a14 turbo motor build up datto1000wagon 2009/5/27 7:09
           Re: killer a14 turbo motor build up broccoli 2009/5/27 8:53
       Re: killer a14 turbo motor build up D 2009/5/27 10:19
       Re: killer a14 turbo motor build up revhead001 2009/5/27 22:14
         Re: killer a14 turbo motor build up datto1000wagon 2009/5/28 0:21
         Re: killer a14 turbo motor build up broccoli 2009/5/28 0:42
       Re: killer a14 turbo motor build up D 2009/5/28 1:25
         Re: killer a14 turbo motor build up nick_m 2009/5/28 2:11
           Re: killer a14 turbo motor build up datto1000wagon 2009/5/28 3:18
             Re: killer a14 turbo motor build up broccoli 2009/5/28 6:15
               Re: killer a14 turbo motor build up datto1000wagon 2009/5/28 7:01
               Re: killer a14 turbo motor build up steveo 2009/5/28 7:14
       Re: killer a14 turbo motor build up nick_m 2009/5/28 3:49
       Re: killer a14 turbo motor build up sikdatto1200 2009/5/28 5:07
       Re: killer a14 turbo motor build up broccoli 2009/5/28 7:10
       Re: killer a14 turbo motor build up spenc 2009/5/28 9:41
         Re: killer a14 turbo motor build up datto1000wagon 2009/5/28 9:52
       Re: killer a14 turbo motor build up affordableperformance 2009/6/3 11:21
         Re: killer a14 turbo motor build up datto1000wagon 2009/6/3 11:37
       Re: killer a14 turbo motor build up sikyne 2009/6/3 11:52
         Re: killer a14 turbo motor build up datto1000wagon 2009/6/3 12:26
       Re: killer a14 turbo motor build up sikyne 2009/6/3 12:35
         Re: killer a14 turbo motor build up datto1000wagon 2009/6/3 12:51
           Re: killer a14 turbo motor build up sikyne 2009/6/3 13:13
             Re: killer a14 turbo motor build up datto1000wagon 2009/6/3 13:25
               Re: killer a14 turbo motor build up LAGWAGON 2009/6/3 14:15
       Re: killer a14 turbo motor build up D 2009/6/3 16:23
       Re: killer a14 turbo motor build up A14-Turbo 2009/9/8 15:01
         Re: killer a14 turbo motor build up Datsun1000 2009/9/8 15:34
       Re: killer a14 turbo motor build up Dundee1000 2009/9/8 16:10
       Re: killer a14 turbo motor build up lamb_daiquiri 2011/1/17 10:02
       Re: killer a14 turbo motor build up Timtams 2012/10/10 1:54
       Re: killer a14 turbo motor build up sikyne 2012/10/10 5:13
         Re: killer a14 turbo motor build up Stock1200Ute1 2012/10/10 5:47
