Re: killer a14 turbo motor build up
depending on the quality of the cast ay head boost could be an issue.
Either way if you bought the roller rockers already you should consider
just clean ports with heat proof coatings where you can a turbo camshaft
and a rev limit of 7K rpm for durability.
The roller rockers will already be enough with good valve springs.
Posted on: 2009/5/27 5:25
Subject Poster Date
     killer a14 turbo motor build up datto1000wagon 2009/5/25 13:33
       Re: killer a14 turbo motor build up clyons8 2009/5/25 14:02
         Re: killer a14 turbo motor build up Dundee1000 2009/5/25 15:25
       Re: killer a14 turbo motor build up luis12 2009/5/25 20:28
         Re: killer a14 turbo motor build up luis12 2009/5/25 20:30
           Re: killer a14 turbo motor build up datto1000wagon 2009/5/25 21:49
             Re: killer a14 turbo motor build up steveo 2009/5/26 2:29
       Re: killer a14 turbo motor build up D 2009/5/26 2:04
       Re: killer a14 turbo motor build up maso-13 2009/5/26 2:42
         Re: killer a14 turbo motor build up steveo 2009/5/26 11:57
           Re: killer a14 turbo motor build up datto1000wagon 2009/5/26 12:17
             Re: killer a14 turbo motor build up Ianey 2009/5/26 13:36
       Re: killer a14 turbo motor build up D 2009/5/26 15:22
       Re: killer a14 turbo motor build up clyons8 2009/5/26 21:22
         Re: killer a14 turbo motor build up nick_m 2009/5/26 22:57
       Re: killer a14 turbo motor build up maso-13 2009/5/26 23:40
         Re: killer a14 turbo motor build up datto1000wagon 2009/5/27 0:27
       Re: killer a14 turbo motor build up maso-13 2009/5/27 1:44
       Re: killer a14 turbo motor build up broccoli 2009/5/27 3:57
       Re: killer a14 turbo motor build up D 2009/5/27 5:25
         Re: killer a14 turbo motor build up datto1000wagon 2009/5/27 7:09
           Re: killer a14 turbo motor build up broccoli 2009/5/27 8:53
       Re: killer a14 turbo motor build up D 2009/5/27 10:19
       Re: killer a14 turbo motor build up revhead001 2009/5/27 22:14
         Re: killer a14 turbo motor build up datto1000wagon 2009/5/28 0:21
         Re: killer a14 turbo motor build up broccoli 2009/5/28 0:42
       Re: killer a14 turbo motor build up D 2009/5/28 1:25
         Re: killer a14 turbo motor build up nick_m 2009/5/28 2:11
           Re: killer a14 turbo motor build up datto1000wagon 2009/5/28 3:18
             Re: killer a14 turbo motor build up broccoli 2009/5/28 6:15
               Re: killer a14 turbo motor build up datto1000wagon 2009/5/28 7:01
               Re: killer a14 turbo motor build up steveo 2009/5/28 7:14
       Re: killer a14 turbo motor build up nick_m 2009/5/28 3:49
       Re: killer a14 turbo motor build up sikdatto1200 2009/5/28 5:07
       Re: killer a14 turbo motor build up broccoli 2009/5/28 7:10
       Re: killer a14 turbo motor build up spenc 2009/5/28 9:41
         Re: killer a14 turbo motor build up datto1000wagon 2009/5/28 9:52
       Re: killer a14 turbo motor build up affordableperformance 2009/6/3 11:21
         Re: killer a14 turbo motor build up datto1000wagon 2009/6/3 11:37
       Re: killer a14 turbo motor build up sikyne 2009/6/3 11:52
         Re: killer a14 turbo motor build up datto1000wagon 2009/6/3 12:26
       Re: killer a14 turbo motor build up sikyne 2009/6/3 12:35
         Re: killer a14 turbo motor build up datto1000wagon 2009/6/3 12:51
           Re: killer a14 turbo motor build up sikyne 2009/6/3 13:13
             Re: killer a14 turbo motor build up datto1000wagon 2009/6/3 13:25
               Re: killer a14 turbo motor build up LAGWAGON 2009/6/3 14:15
       Re: killer a14 turbo motor build up D 2009/6/3 16:23
       Re: killer a14 turbo motor build up A14-Turbo 2009/9/8 15:01
         Re: killer a14 turbo motor build up Datsun1000 2009/9/8 15:34
       Re: killer a14 turbo motor build up Dundee1000 2009/9/8 16:10
       Re: killer a14 turbo motor build up lamb_daiquiri 2011/1/17 10:02
       Re: killer a14 turbo motor build up Timtams 2012/10/10 1:54
       Re: killer a14 turbo motor build up sikyne 2012/10/10 5:13
         Re: killer a14 turbo motor build up Stock1200Ute1 2012/10/10 5:47
