1200 L conversion
From hastings,vic
just would like to no wots needed for L conversion in 1200
pro's and con's, 1600/2000,wot sump, box ect
thanks tommo
Posted on: 2009/5/31 11:39
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
Re: 1200 L conversion
From Armidale N.S.W
Just to start Bluebird sump or even 200b sump and oil pick up off the same motor, Stumpy stanza box 4 or 5 speed and Auto 1200 tailshaft, 120y H150 diff minimum i reckon, Thats what im headin for. L20b is a tall motor they go in with some fiddling mainly sump mods. We are going L16 then up to L18 with L16 head in Mr Hanky. Gotta mod or make new mounts on 1200 cross member. We are using mounts off a stanza cross member as recommended by PIGDOG. Hes one of the best guys to talk to about it and he keeps it practical.
Posted on: 2009/5/31 11:56
73 1200 wagon SOLD
From Geelong, Vic
ive got a whole L series setup that i'll sell with my L18
2L L18 with 95rwkw, built for rallying and cost over $7000 to build 4 years ago
L series crossmember, sits the engine very very low and as far back as it can be
R30 stumpy box with all new bearings
Tailshaft to suit H165 ute diff
180b gearbox crossmember, need to weld 180b mounts to the car and its all factory looking
pretty much everything out of my 1200 that i didnt reuse for the CA
PM for price
Posted on: 2009/5/31 12:09
From Armidale N.S.W
We could have dropped that in while i was down there. Shall i head back ? HA HA. NAh i only want the sump and cross member. Please
Posted on: 2009/5/31 12:16
73 1200 wagon SOLD
From Melbourne, Aus
Tommo,
I did this conversion on my last coupe.
As Andy has said, i also used a stanza 5 spd and stanza sump with an L20.
I didn't have to mod the sump however.
For the crossmember, I cut the mounts down.
I used r30 skyline engine mounts.
I used a ute diff and a cut down tailshaft. (I didn't know about the auto tailshaft)
let me know if you need anymore info,
cheers
Bruce
Posted on: 2009/5/31 12:18
From Geelong, Vic
did you notch the crossmember? coz an un modded sump would mean the engine is sitting really high
also can use L20b ruber mounts as they are smaller than R30 ones, meaning engine sits lower
mine with an L20b could still fit the stock carby and filter assembly with a 10mm spacer under the carby
and auto tailshaft only works with 1200 and 120y BW diffs, h145s and h150s as there was never any auto utes...so for a ute diff you need to cut down something else, stanza or bluebird tailshafts have the right ends
Posted on: 2009/5/31 12:34
From hastings,vic
will it fit in a manual/auto 1200 or 120y tunnel
Posted on: 2009/5/31 12:56
From Geelong, Vic
ive got a 180b tunnel in my car which is the same size as a 120y tunnel, which is like a 1200 auto tunnel with a larger bellhousing section
Posted on: 2009/5/31 13:21
From hastings,vic
so any one got a 120y tunnel for sale
Posted on: 2009/5/31 13:36
From Geelong, Vic
ive also got a 120y tunnel...but i need it for the wagon
Posted on: 2009/5/31 13:39
