Cheap Halogen Lights
From Perth Austarlia
Don't buy a conversion kit for $140 plus, find a subaru sherpa being wrecked. These "cars" have 7 inch halogen lights!! The lights fit in the datsun holder except for the small third light??
A simple mod to the light holder will make the light fit perfectly.
Posted on: 2003/8/22 15:12
Re: Cheap Halogen Lights
From Sydney, Australia
Thanks man..that's a great suggestion.
I bought some new Hellas already..but it's definitely a great budget tip!!
Chris
Posted on: 2003/8/22 16:03
Halogen sealed lights and bulbs are commonly available in the USA and inexpensive as well.
But the Hellas and most conversion kits have extra-high power lights, right?
Posted on: 2003/8/22 20:42
Most Halogen lights have removable (replaceable) elements. The H4 ones for example. So I figure if these are Halogen, then they'll be the same as the Hellas. As the replacement globes are common parts, and surely not specifically for the aftermarket units. Whether they be Narva,Hella etc etc.
So if you bought these units, then got higher power replacement globes, then wired up the lights with thicker wire to handle the current..it'd be all good. I got high powered "made in poland" H4 globes in Poland for $5 each.
Chris
Posted on: 2003/8/22 23:53
ive got the hellas as well, and put navara 55/100 globes in them... they work really well when aimed... at taxi drivers heads.
Posted on: 2003/8/23 6:01
From San Diego California
I've got HIDs that are going in as soon as
I start the engine transplant later this year
took Lexus IS300 headlamps and cut them
apart then glue into the back of lights I
bought at the goodguys hotrod show
I tested them and the work great but I
have to figure out how and where to mount
the transformers.... will have pictures of the
whole project once it starts....
Wubbits
Posted on: 2003/8/23 7:46
From Tassie, Australia
$140! WTF? Who are you pricing the kit through? I just did the conversion from sealed beams (circa 1974) to H4 halogen semi sealeds in the XB and it cost me a lot less and they are all new parts.
Head down to your local Super Cheap Auto store: Semi Sealed beams $17.99 each x 2, Autotechica H4 Opti Blue Platinums $24.99 pair = $60.97, 15mins of your weekend and hey presto, halogen lights. This was the best $60 I have ever spent and it has made a major improvement. I only got the 60/55W globes, the 100/90W are overkill and as someone said you would have to beef up the wiring.
I recomend it to anyone who comes in to buy sealed beams, #### it I recomend it to anyone.
Cheers,
Simon
Posted on: 2003/8/24 11:38
not only are the 90/100w bulbs overkill and a drian that may fry the wiring, they are also illegal in AUS. I found ausram 55/100w bulbs that are certified as adr complianced for $10 each at kmart. best investment cause how oftem do you drive with the headlights on highbeam for extended periods of time in residentail areas, unless your like me.
Posted on: 2003/8/25 7:01
From NorCalifornia, up by Sac
you=pronoun=the nominative and objective singular and plural pronoun of the second person, used in addressing one or more persons, animals, or things, and ALWAYS taking a plural verb....you'd=you had....you'll=you will....your=pronominal adjective=the possessive case of the pronoun 'you', used attributively....you're=you are....yours=pronoun=the possessive case of the pronoun 'you', used predicatively....yourself=pronoun=a form of the second person pronoun, used as a reflexive or as an object of a preposition in a reflexive sense....you've=you have........Sorry, drunk again. Carry on.
Posted on: 2003/8/25 8:14
From Warwick, QLD
WTF????
Posted on: 2003/8/25 8:37
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
