#1 Axle Length?
hotrocket Posted on: 2009/6/2 3:51
Are B120 ute axle's the same length's as each other?
#2 Re: Axle Length?
PIGDOG Posted on: 2009/6/2 4:14
yes
#3 Re: Axle Length?
ddgonzal Posted on: 2009/6/2 4:25
Correcto. All 1200 axles are same length RH and LH side are interchangeable.
B110 & B210 axles are the same (H145/H150 same)
H165 ute and H165 B210 axles are same.
#4 Re: Axle Length?
hotrocket Posted on: 2009/6/2 5:29
Thanks fella's i wasnt to sure as i recived a diff housing with to axles in it looking to same,
thanks cheers rod.
#5 Re: Axle Length?
hotrocket Posted on: 2009/6/9 0:14
next question: are 120y's and 1200 ute's use the same axle?
#6 Re: Axle Length?
ddgonzal Posted on: 2009/6/9 3:40
Yes: 120Y with H145 diff, 1200 ute with H145 diff.
Other 120Y NO: uses BW diff
#7 Re: Axle Length?
hotrocket Posted on: 2009/6/9 3:51
thanks there dav, i new you come through, cheers
