s13 brakes
Quite a regular
From Brisbane
hey just after a bit of help i have just started doing the s13 conversion onto disk strut on my ute... now i have 280mm rotors which i have only now realized.... has any1 else done this conversion using the 280mm rotors?
any help would be awesome coz i have no idea
cheers Jay
Posted on: 2009/6/2 4:55
Re: s13 brakes
From Wagga Wagga, NSW
its all the same to fit 280mm rotors then it is to fit the 250mm's
Posted on: 2009/6/2 6:13
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
i thought you might say that
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
Re: s13 brakes
From Geelong, Vic
yeah they use the same bracket, same with using skyline (r32, r33) brakes
Posted on: 2009/6/2 7:01
Re: s13 brakes
From Christchurch NZ
be careful that the calipers for the 280mm rotors still only have the 37mm pistons. Mnay of the larger single pot nissan brakes use a 47mm piston'd caliper. I've found that the 47mm piston'd calipers foul on the caliper adapter brackets severely. As it was I had to shave a whisker off my s13 calipers to clear the stub axle mounting eye.
Posted on: 2009/6/2 7:07
Forced Induction!
Re: s13 brakes
Quite a regular
From Brisbane
do i have to drill new holes?
dont spose any of you guys could post some pics up at all? or better yet email them to me?
mazdarx3_13bturbo@hotmail.com is my address neways
cheers Jay
Posted on: 2009/6/2 7:13
Edited by 13b1200ute on 2009/7/6 7:00:20
Re: s13 brakes
From brisbane, QLD
hey guys..
are the calipers the same size for the 250mm rotors to to 280mm rotors..
thanks blair..
Posted on: 2009/6/2 11:25
Clint at Profile Autosports and tuning for all mechanical needs and dyno tuning Brisbane..
current rides..
02 hilux daily.
ca18det 1200 ute
Re: s13 brakes
Good question!
I have some calipers off a cefiro, and I've seen some s15 calipers too. Both of them had the bigger pistons. They also have bigger pads too. With an A series, the 250mm brakes are more than sufficent.
Posted on: 2009/6/3 10:09
Forced Induction!
Re: s13 brakes
Quite a regular
From Brisbane
has anyone done this 280mm conversion ?
Posted on: 2009/7/6 7:00
Re: s13 brakes
From brisbane
Hi mate
I have.
I started out with the CA18DET (250mm rotor) brakes several years ago and changed to the SR20DET (280mm rotor) brakes around 18 months ago.
I had to clearance the calipers very slightly to run the same brackets.
Both sets of brakes were from S13 Silvias.
Matty
Posted on: 2009/7/6 13:09
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
