« 1 (2)
#11 Re: sway bars on the rear of 1200 utes wat u got ?
perthute Posted on: 2009/6/9 10:00
bolts too the chassic rails
#12 Re: sway bars on the rear of 1200 utes wat u got ?
maso-13 Posted on: 2009/6/9 10:10
what is the sway bar from mate?
#13 Re: sway bars on the rear of 1200 utes wat u got ?
perthute Posted on: 2009/6/9 10:12
un shore was a brand new item from pedders bolt on over the counter job
#14 Re: sway bars on the rear of 1200 utes wat u got ?
maso-13 Posted on: 2009/6/9 10:14
so it was made for the 1200 ute ? if you dont mind me asking how much are they ?
#15 Re: sway bars on the rear of 1200 utes wat u got ?
perthute Posted on: 2009/6/9 10:33
forget hey was 4 years ago now
#16 Re: sway bars on the rear of 1200 utes wat u got ?
ratsun_a14 Posted on: 2009/6/9 11:09
Have u got a pic of where it bolts to the chassis rail?
Did it have any effect on handleing?
#17 Re: sway bars on the rear of 1200 utes wat u got ?
perthute Posted on: 2009/6/9 14:43
i did have a big problem with inside wheel lifting and open center diff spinning the hell out of the wheel in the air , after the sway bar was fitted it only lifted dueing heavy corners
will try n get more pics tomorro
#18 Re: sway bars on the rear of 1200 utes wat u got ?
jeffroj Posted on: 2009/6/10 5:27
Can the attachments to the diff be moved in or out if so would this give some sort of adjustment to the stiffness.
« 1 (2)
