Re: s13 adj camber tops
not bad, you will probably need the spacer, also a bearing to help the top hat spin like the stock set ups, other wise might undo shock nut from time to time...
Posted on: 2009/6/14 13:10
Subject Poster Date
     s13 adj camber tops SomeDAT 2009/6/12 9:25
       Re: s13 adj camber tops LittleFireyOne 2009/6/12 9:47
       Re: s13 adj camber tops Anonymous 2009/6/14 13:10
         Re: s13 adj camber tops broccoli 2009/6/15 1:19
           Re: s13 adj camber tops SomeDAT 2009/6/16 13:21
             Re: s13 adj camber tops PIGDOG 2009/6/16 13:35
       Re: s13 adj camber tops SomeDAT 2009/6/16 13:52
       Re: s13 adj camber tops Anonymous 2009/6/17 0:15
