Sunny B310 manual conversion..
hey guys recently changed my 1980 Sunny B310 over to a manual, got a 4 speed sunny gearbox in at the moment. just wanting to change it to a 5 speed. would i have to put a sunny gearbox in or would any other gearbox's fit? cheers
Posted on: 2009/6/14 13:46
Re: Sunny B310 manual conversion..
From illawarra, nsw australia
if you dont want to be mucking around with gearbox crossmembers
Then generally you would stick with a sunny box
1980 B310 =a15 = 60 series gearbox, correct?
Posted on: 2009/6/14 14:22
yeah thats true, just heard that the original sunny 5 speeds aren't very reliable, not sure how true that is though. wouldn't have any clue how much u could pick up a 60 series gearbox 4, thats the 5 speed right?
Posted on: 2009/6/14 15:12
From sydney australia
Your problem isn't how reliable (very reliable), but in finding one. The supply in Australia dried up long ago, with only the occasional private sale or wrecker having one. That's why Toyota gearboxes are used with an adaptor/bellhousing. Dellow do the most common kit, but people on this site have made their own using the bellhousing from a A series auto. So if you can find a 5 speed it'll go straight in & shouldn't cause any problems, especially if you fit new bearings first. But it might be cheaper & easier to get the Toyota box & the Dellow kit. Are you still using the A12 or is it an A14/15? The overdrive 5 speed really wont be much use around town, but is an advantage on the open road.
Posted on: 2009/6/17 0:20
From pooraka,,adelaide
5spd's are worth a bit
Posted on: 2009/6/17 2:02
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
ohk yeh i heard that they were pretty hard to come by, ohk sweet il have to check that out. im still using the original A12, i do a lot of country driving and the 5th gear would just come in handy alot. i think il just keep and eye out 4 a Toyota box with the bellow kit, will be a lot easier, cheers much appreciated
Posted on: 2009/6/19 16:02
