accelerator bolt
From cold toast
does or did anyone have a bolt that stopped the accelerator from going all the way down to the floor in there 1200 ute?
if so, whats it for?
edit: oh and it is bolted to the floor pan
Posted on: 2009/7/1 12:27
Re: accelerator bolt
From sydney australia
Yes,that bolt is there so you get a solid stop before you get full throttle. It's only a 6 mm bolt with a locknut at the floor. If the throttle pedal is at it's full travel (ie on the firewall) it doesn't really do anything, but all my 1200's got full throttle before that. You risked bending linkages without it & you wouldn't get full throttle next time you needed it. As I say, it's just a long 6 mm bolt into the floor,the secret was to get full throttle using your hand on the accelorator pedal, then wind out the bolt so it moved the pedal back slightly. You'd then be guaranteed of getting full throttle every time.
Posted on: 2009/7/2 2:00
From northern 'burbs adelaide
i had a problem with my pedal getting caught under it lol and it held the car at full revs so i took it out
Posted on: 2009/7/2 7:33
From cold toast
i saw it and i was like wtf and pulled it out hahahaha
so will it break my engine?
Posted on: 2009/7/2 10:59
From Brisvegas, oz
as b310 said you will bend linkages and possible snap your accelerator cable
Posted on: 2009/7/2 11:05
www.camerasplus.com.au
From cold toast
ooooooo
thats not a good idea then
i should try put it back in hey
Posted on: 2009/7/5 2:42
