« 1 (2) 3 »
Re: What diffs have you put in a 1000?
From perth airport
im about to do the 1200 ute diff convershion to my 1000. i thinks its about 50 mm wider each side . im going to run flares so thats fine . moving the mounts . and get tailsharft changed to suit the ute diff is all the problems i think i will run into
yes stevo runs a ute diff in his :)
i understand the diff will be heavyer but im on my 3rd 1000 diff and shes sounding upset atm so that will be 4 diff's that the car has kill'd
time to upgrade :)
Posted on: 2009/7/10 7:33
perth airport parking
Datsun 1200 ute A14
From Sydney
Can anybodoy tell me more about the H150/H190. Im guessing the h190 centre bolts into the h150 housing. What did come in? What ratio's? and are they much lighter than the pintara?
Posted on: 2009/7/10 7:37
From Adelaide, Australia
No H190 does not fit into a H150 housing...
I would go a H165, you'll have trouble breaking that, move the leaf spring pads get a ute tailshaft and it should bolt in, otherwise find a H150/H165 sunny or 120y tailshaft and get that shortened, at least it will have the correct flange on it.
Although saying that, what do you boys do to your H145's to get them to break so often, I have run plenty of locked H145s over the years, only broken axles and a couple of centres I have swapped because they sounded too clunky.
Posted on: 2009/7/10 7:42
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From perth airport
i drive my 1000 wagon very hard has its a fun car = broken diff's
the locker h145 seems to have lasted the longest for me but now is so noisy i cant go over 60kph
Posted on: 2009/7/10 7:55
Datsun 1200 ute A14
A 1000 at 60kph??? suprised it will go any faster.... lol
Ahh the fun stuff happens above burnout pace where diffs don't really break unless you have hp.
Posted on: 2009/7/10 8:16
IPRA Build
From Perth
Who did your diff Ruben ?
Posted on: 2009/7/10 8:19
From perth airport
WhiteSedan Ahh the fun stuff happens in 1000's coz 1200's are too heavy
just fixx'd that one for ya :P
Posted on: 2009/7/10 9:08
Datsun 1200 ute A14
From newcastle, NSW
yep i just installed a H165 ute diff in my 1000, well a month or two ago. I went through the same train of thought you did Gav, i contemplated getting a bigger diff shortened like the other boys have done but i'm only running an A14 turbo and i want to keep it as light as possible, and i realised that a skyline R31/commodore diff is a heavy lunk of a thing and the H165 is only a bit heavier than the stock diff and relitively easier conversion.
I used a ute diff and it's about 30mm wider on each side, as stated before you need to either get the right offset wheels or just put flare on, i'm going to be using flares. I found out you can't use a shorten a ute diff because after it has been shortened there isn't enough for the splines. The only option would be to shorten a Bluebird H165 diff seeing that they're wider, if you want to go down the shortened H165 but if you want to go down that route you may as well go and get a H190 out of a series 3 bluebird, but they're obvouisly a fair bit heavier again.
I looked into the Alfa LSD that D mentioned but they are far and few in between, i was originally looking for an LSD but i'm hoping to purchase a Topgear builtr LSD for the H165 housing.
what do you boys do to your H145's to get them to break so often?
It's funny what a bit of boost can do!!!!
Posted on: 2009/7/10 12:29
From Sydney NSW
Apparently a h150 centre will fit into a h145 housing with a couple mill adapter plate to widen the housing a little. This sounds like one of the better options to me because you get to keep the original lighter alloy housing. For a stronger but still light option, you want to check out the alloy h165 LSD on ebay, but i have a feeling its not going to go cheap..
Posted on: 2009/7/10 12:56
From newcastle, NSW
H150 isn't that much stronger than the H145 espeically when boost is involved, H165 is much better, i had in my CA18det powered coupe it handled the power pretty well.
That alloy diff centre would be a good catch! i wonder if its a Topgear built unit?? but more than likley a 'pitroad' item.
Posted on: 2009/7/10 13:19
Edited by steveo on 2009/7/10 14:15:08
« 1 (2) 3 »
