Browsing this Thread:
1 Anonymous Users
L/A hybrid oil pump? |
From Melbourne, Oz
Anybody who has done this mod giv me detailed details? posaby with pic's?
Thank's Heaps
Posted on: 2009/7/13 4:45
"I hav achieved wood"
Re: L/A hybrid oil pump? |
Registered Users Contentmaster Usermaster
Nissan Competition sold it. The L-series has a thicker rotor, so extra volume. Just have to machine up a center section to match.  Measurements and Photos: Hi-Volume Oil Pump
Posted on: 2009/7/13 5:32
From Melbourne, Oz
Sweet, gona pop down the parts store to get one of eatch!
Posted on: 2009/7/13 5:49
From Christchurch NZ
I had one made, but it wasn't easy. I think in the end the guy made a new shaft to carry the L series pump rotor. We used part of an old housing as a packer to make up for the thicker gear. And silversteel dowels to hold everything in position.
Posted on: 2009/7/13 10:02
Forced Induction! Because everyone knows you don't bring a knife to a gunfight!
From Melbourne, Oz
Im sure if it can be done I can do it looks as'though you may just be able to modifie the mountin surface and ajoining shaft/boss to fit the 'a' block?
will take progress shots when I do so.
or maybe just split 2 'a' bodies unevenly and use the 2 bigger halves?
Posted on: 2009/7/13 10:19
From newcastle, NSW
i noticed in the wiki article there is a hand drawn diagram showing all measurements and dimesions of the parts, has anyone got a clearer version of that diagram?
Posted on: 2009/7/13 11:24
I have not actually done it but I secured all the parts & started to measure things up, .... & it isn't quite that easy.
The idea is to use the 'L' series internals in an 'A' series pump body, so the first things to measure are the two shafts. You will find that the L series shaft is too short & it measures 1/2" in diameter. [well, mine did]
The A series shaft is 12mm in diameter, which is smaller, so the hole in the pump body will be smaller than the L series shaft.
The length problem can be overcome by pushing out the pin in the rotor, then pushing the shaft outward untill the protrusion matches the A series & filling the resulting hole in the bottom of the rotor with silicon or some other suitable material, but you still need to be able to get it into the A series pump body. This can be done by enlarging the hole or machining down the shaft.
If you enlarge the hole in the pump body, then you will also need to enlarge the hole in the drive gear so it will fit the larger shaft size.
If you machine the shaft down, then you can only machine the part that goes into the pump body because you will still need the larger diameter inside the pump rotor to hold it
Next, you need to realise that the L series pump is driven by a tang on a drive shaft. This means that the end of the shaft where the drive gear will now sit has a slot in it which will weaken the shaft right where it needs to be dimentionally stable in order to properly secure the gear.
My preferred solution is to have a new shaft made up that has the proper 1/2" diameter for the rotor to sit on & the remainder at 12mm diameter where it fits into the pump body & of the correct length for the A series application.
This way it all goes together like a factory job.
As for the spacer to allow the use of the L series rotors, .... that's your problem.
Posted on: 2009/7/13 13:28
Love your Datsun. Treat it well.
From Melbourne, Oz
to easy mate!
Posted on: 2009/7/14 8:48
