Mark64 wrote:
Yeah I think your rear heater port comes out of the back of the head. I am putting my a14 into an mg too, but mine will be without a heater so I am thinking of connecting the two header ports up just to get some heat out of the back of the head and help in circulation.
The hot water supply for the heater comes from the back of the head, but temperature regulation at the heater is done by controling the amount of water that flows through the heater core.
In summer, the heater is normally turned to the 'no heat' position which closes off the water supply completely. This means that during the hotest part of the year, there is no coolant drawn from the back of the head, yet the engine sufferes no ill effect.
Just plug this hole & don't wory about additional plumbing that will have no beneficial effect whatsoever.
The hole at the back of the block is indeed the direct link to the crankcase for the removal of nasty crankcase vapours & the means of preventing crankcase pressure build up.
It will be a wise man who retains the PCV function, even if it means a little custom plumbing to clear the firewall or other obstructions.
