#1 adjustable front arms
iDatto Posted on: 2009/7/20 12:12
http://maddat.com.au/suspension-parts.php
"1200 Adjustable Front Arms"
are these for camber?
#2 Re: adjustable front arms
WhiteSedan Posted on: 2009/7/20 12:13
Yes... best off if you can, adjust camber from the strut top, that way you don't have an increase in front track.
#3 Re: adjustable front arms
iDatto Posted on: 2009/7/20 12:16
that makes sence
can you get adjustable strut towers for 120y shocks though?
#4 Re: adjustable front arms
WhiteSedan Posted on: 2009/7/20 12:18
Most of the strut inserts will have the same thread on the end and I think the maddat ones come with all the combinations of spacers and nuts to make it work, otherwise Im sure if you buy the strut tops from maddat scott would make it all work for you.
#5 Re: adjustable front arms
iDatto Posted on: 2009/7/20 12:20
rad :)
ill try get him on his email
#6 Re: adjustable front arms
arent the adjustable lower arms illegal for road use?
#7 Re: adjustable front arms
perthute Posted on: 2009/7/20 12:31
more than likly illegal
i had camber tops and didn't get me the amount of camber i wanted so i got the adj lower control arms
#8 Re: adjustable front arms
Posted on: 2009/7/20 12:33
yeah i dont get much past 2 deg neg with camber tops, more like 2.5 max
#9 Re: adjustable front arms
perthute Posted on: 2009/7/20 12:37
i didnt get mine set buy a shop so i dont know wat the camber was but it wasnt much by eye
now with the adj LCA set too max its crazy ( i only set it so max for #OOPS# n giggles ) my ute is a long way from hitting the road
#10 Re: adjustable front arms
iDatto Posted on: 2009/7/21 8:13
haha, yeah i only want the camber for looks,
not interested in cornering real well haha
2 degrees should keep me out of trouble, or really, get me into it
