#1 Vanette Questions
nismo Posted on: 2009/7/21 12:33
Hi all I have bought myself a 1985 nissan vanette, and just want to know if the front disc brakes and wheels fit onto a 120y???????
Also if there's any other mechanical parts, other then the motor that interchange with a 120y, I would like to know.
Thanks, James.
#2 Re: Vanette Questions
SaCoupe73 Posted on: 2009/7/21 13:03
Dude, if its a C20 vanette it will have a H165 diff in it with a 4.875 ratio.
that ratio is hard to get and will fit most late 70's 1200 ute diffs.
A ute diff might fit under your 120y and will be way stronger than the standard one.
Geoff
#3 Re: Vanette Questions
DattoFrog Posted on: 2009/7/21 14:37
If it is a C120 with a 5spd you can use the trans as well. They can be converted from colum to floor.
#4 Re: Vanette Questions
LittleFireyOne Posted on: 2009/7/21 16:53
Seen my pics? the brakes could work if you have the larger stanza\180\200b stub axles.
#5 Re: Vanette Questions
nismo Posted on: 2009/7/21 23:40
It's a C120 vanette with a 60 series 4-speed column change.
Thanks guys oh and what diff ratio do they run??????
Cheers.
#6 Re: Vanette Questions
ddgonzal Posted on: 2009/7/22 2:59
You tell us: What does the underbonnet chassis ID plate say?
