timing
From durban, south africa
hey guys,
what do you guys set your timing to with you performance cams??
many thanks
nicholas
south africa
Posted on: 2003/9/3 15:00
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: timing
From Mandurah WA
Ignition timing ? Cam timing ??
Posted on: 2003/9/3 15:40
1984 Mazda 626 stocker..
Soon to be 32/36 weber powered
Re: timing
both, let's get some group input
Posted on: 2003/9/3 15:46
VW chassis
fibreglass body
A-14
280 cam
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
Re: timing
From Wellington New Zealand
Depends on the cam! the cams I've used have liked being around 102 degrees.
I cant seem to get much more than 33 degrees ignition advance (at the peak torque RPM) in a high compression A engine.
Posted on: 2003/9/3 21:29
Re: timing
From Millgrove Vic OZ
Nicholas,
I find your avatar even more hypnotic than Mikali's!!!
Posted on: 2003/9/4 6:19
Cheers Feral
Re: timing
oh well, too bad ive set it to 15 degree's, its not pinging so it should be alright thanks for the input
Posted on: 2003/9/4 14:17
VW chassis
fibreglass body
A-14
280 cam
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
Re: timing
From Melbourne, Australia
THEY ARE HUGE.........angles tsillay
Posted on: 2003/9/4 14:22
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
