Re: help gx head thickness
74mm is fine. You don't want to skim it any more. Why would you use a thicker gasket? Don't you want the extra compression ratio?
GX heads came stock with an extra-thin metal headgasket. If using the flat-top pistons it was 10:1 compression.
Posted on: 2009/7/24 6:28
Subject Poster Date
     help gx head thickness nismo1 2009/7/23 18:21
       Re: help gx head thickness ddgonzal 2009/7/24 6:28
       Re: help gx head thickness nismo1 2009/7/24 6:43
       Re: help gx head thickness A14force 2009/7/24 7:51
         Re: help gx head thickness nismo1 2009/7/24 8:12
         Re: help gx head thickness ddgonzal 2009/7/24 8:14
       Re: help gx head thickness 1200GXman 2009/7/24 8:33
       Re: help gx head thickness racetech 2009/7/24 10:16
       Re: help gx head thickness superbin 2009/7/24 11:26
       Re: help gx head thickness 1200GXman 2009/7/24 13:54
