Re: car dies while driving
Quite a regular
From pretoria, south africa
its weird that the flicker light would come on with the charge light sometimes.. you could have a bad earth, so go through all your earth wires and make sure they`re metal to metal, that or someone messed up with the wiring somewhere, i`m probably not much help, but just keeping the post going so you can be helped, but like the other guy said earlier in the post.. service it.. like just go through everythi9ng and make sure everything works.. all your lights and stuff
Posted on: 2009/7/27 18:17
Hi all. Normally I would do the "Hi, here I am, this is my car..." introduction, which I will shortly after I sort some gremlins of my own, however after reading about this problem I thought I'd share what has happened to me before. Your problem could be different to one I've had previously, but I've had a certain little juvenile drop a packet of cigarette papers in my fuel tank. This would cause the papers to float freely until one would pass under the fuel pickup and block off fuel flow. As the car coasted to the roadside, the papers would float away allowing the car to behave normally. That is, until it picked up the papers again....
Hope you solve the mystery.
Posted on: 2009/7/27 20:56
From Armidale N.S.W
Also had a similar problem the ignition barrel was worn, after years of keys on a keyring bouncing around i imagine. Mine would die you touch the key and it would cut back in. If you have another ignition handy or access to one plug it in and take it round the block see what happens.
Posted on: 2009/7/28 1:56
73 1200 wagon SOLD
From Perth WA
I feel your pain, nothing worse than intermittent problems. a backfire could mean the timing is way out and that would cause stalling too. it could be to do with fuel pressure as jmac said also.
Posted on: 2009/7/28 2:53
datsun 1000, Its not the size its how u use it.
Hi, thanks for all the posts!
Also want to ask, what is the signs of a defective coil and condenser?
Posted on: 2009/8/19 6:09
Intermittent poor running. If it is Datsun electronic ignition, you can remove the condensor.
Posted on: 2009/8/19 6:30
Could a defective coil cause the car to cut out while driving??
Posted on: 2009/8/19 7:17
Or a faulty fuel pump cause car to cut out while driving?
Posted on: 2009/8/19 7:18
A default anything just about ...
Posted on: 2009/8/19 7:25
From Sri Lanka
hI mila1200
I also had the slimier problem last week, actually it was a problem with fuel pump,that did not deliver fuel continuously to the carb, just check whether it is providing fuel without failure or delay
thanks
regards
sumith
Posted on: 2009/8/19 7:28
« 1 (2)
