(1) 2 3 »
CA18DET 1200 how much will this roughly cost?
From QLD
Hi Guys, i'm thinking of putting a CA18DET into a 1200 ute, aswell as a stumpy r30 skyline gearbox, a shortened r31 diff, custom tailshaft, and wiring loom, and stanza front suspension. I know heaps of these conversions have been done and i'm just wondering how much it all costs, just a rough price. i believe the setup that i have listed is the easiest and best setup to have but if anyone knows different please let me know. All your help will be greatly appreciated.
Many thanks
Scott
Posted on: 2009/7/25 0:04
Re: CA18DET 1200 how much will this roughly cost?
1 billion :P
Posted on: 2009/7/25 2:44
From perth airport
5 grand - 15 grand
think the ca box is stronger than the stumpy box
theres a few guys leaving the stock diff in depends on how u plan on driving the car
can you weld/fab crossmember ? can save you some moni
maddat has a list of every thing you need in a package $$$
imo sr20det is the better choice
Posted on: 2009/7/25 3:09
perth airport parking
Datsun 1200 ute A14
From Brisvegas, oz
when you say your thinking of putting it in do you mean "your" putting it in or your going to pay somebody to put it in?
if your paying somebody expect anything up to $10000 as a very rough cost.
if your doing it yourself it depends on how well you canspot a bargain. a properly completed ca18det should cost about $13000 but you could do it the cheap way and only spend $2000 (this would not be engineered and only have the bare minimum in standards
Posted on: 2009/7/25 3:10
www.camerasplus.com.au
From QLD
Hi Guys, thanks for your repies, i was told that the standard CA box wouldn't fit, so was told that the stumpy gearbox would be better. although ive read alot of problems with changing gear in the stumpy above 5500rpm. I can weld and I'll be doing most of the build myself, apart from a few bits and bobs (some wiring and some bodywork). I was going to put an SR20DET in but aparently its illegal in QLD? i want to do this properly as i love the 1200 utes and want to make a real nice one.
Thanks for your help, keep posting as i need all the help i can get! lol
Posted on: 2009/7/25 3:26
From Brisvegas, oz
have a look through the project builds thread for my current project. it will give you an idea of what i think should be done when putting a ca in. the standard ca gearbox does fit if the tunnel is modded a little. or if you have an auto tunnel already it will fit straight in. the easiest method is using the maddat gear.
with the sr20det you are correct in that qld doesnt allow it.
Posted on: 2009/7/25 3:35
From perth airport
theres guy on hear that have fitted ca18s with the ca box with out putting in a bigger tunnle
the sr20det illegal/legal debait goes on foreva! seems like it depends on the engineer
Posted on: 2009/7/25 3:43
Datsun 1200 ute A14
From QLD
Ive had a look at your ute jake, and dammmmmmm its good lookin.
Posted on: 2009/7/25 3:48
I'm just wondering how much it all costs
Get More Details
Posted on: 2009/7/28 13:24
From perth
i'm hoping to get mine going for around $5k doing EVERYTHING myself
i was given a ca motor suit rebuild and a hilux ute for a diff and gearbox donor
was also given some stanza struts, harnesses and small parts (thanks jordy)
a guy in adelaide gave me a stock ecu
sr20det? national regs DO NOT allow 2.0l w/turbo in a 1200. 1.8l just scrapes in
you will find a lot of help advice and parts here, i have
dazza
Posted on: 2009/7/28 13:49
(1) 2 3 »
