stretching the dattos legs
i have a fairly modified datsun 1000 wagon to which a borg warner diff housing and 3.9:1 center from a 120y and cortina four speed box is fitted. I was thinking of trying to get a bit more top end but i cant find anything lower than a 3.9, i was thinking somthing like 3.5:1 any ideas?
Posted on: 2003/9/7 13:50
Re: stretching the dattos legs
From Melbourne AUS
a 5th gear?
Posted on: 2003/9/7 13:55
1973 B110 A12
From Melbourne, Australia
or bigger wheels, how does a cortina box fit an a-series
Posted on: 2003/9/7 13:59
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
iv thought of that but the cost and hassle are too much
Posted on: 2003/9/7 14:03
its pretty ugly but she holds the grunt, its got 13/7 and they just fit
Posted on: 2003/9/7 14:05
From Hobart Tasmania AUS
What engine have u got in it ?
Posted on: 2003/9/9 10:18
iv got a a15 turbo using a draw thru srtomberg carb running 30+ psi
Posted on: 2003/9/10 15:11
geez man u only tell us this now!
Posted on: 2003/9/10 15:15
1200 Coupe Rallycar
From Brisbane, Australia
wouldn't happen to be red with 'rebel' wheels?
about the diffs, that series BW was used in many 70's Jap car assembled in Aus. I've only looked for lower ratios (3.89, 4.1, and 4.3) in corollas, but I think some other larger cars like Coronas used the same BW diff too - they might have a taller ratio. They'll all be wider housings than the 120Y, but you should be able to swap centres or crownwheel/pinion.
Posted on: 2003/9/10 23:09
Where does this datto 1000 wagon live? I saw a cool red one here in tasmania is it yours.
Posted on: 2003/9/11 1:24
