#1 ca18det harmonic balancer
unit1200 Posted on: 2009/8/1 9:18
hey guys..
was woundering if any one has changed there harmonic balancer to a single drive.. If so wat car did you get it from or where did you get it from..
thanks..
#2 Re: ca18det harmonic balancer
hotrocket Posted on: 2009/8/1 11:29
you me both!! i machined off the first pulley (ca18det) think it will work and bugga it fell-apart
#3 Re: ca18det harmonic balancer
matty Posted on: 2009/8/1 13:07
What about using one the the kits from Ebay?
#4 Re: ca18det harmonic balancer
unit1200 Posted on: 2009/8/1 14:28
yeah had it all pressed together and welded up but not sure about its strength..
#5 Re: ca18det harmonic balancer
unit1200 Posted on: 2009/8/1 14:37
had look on ebay but can't find anting were you loking to find them..
#6 Re: ca18det harmonic balancer
hotrocket Posted on: 2009/8/1 21:47
kits on ebay only do alt,water and p/s not crank
#7 Re: ca18det harmonic balancer
unit1200 Posted on: 2009/8/2 2:34
has anyone done this..
#8 Re: ca18det harmonic balancer
matty Posted on: 2009/8/2 10:58
Hi mate
I'm sure I've seen these on the US Ebay. I could be wrong but it might be worth a look.
Matty
#9 Re: ca18det harmonic balancer
unit1200 Posted on: 2009/8/2 11:25
so do you maen ebay.com
#10 Re: ca18det harmonic balancer
matty Posted on: 2009/8/2 11:57
Yes mate. Failing this an engineering shop would be able to modify a factory one for you I would think.
