Re: No lubrication on top of the rockers.
From Freo
i did mine like that, some of the later oval port heads don't have much meat on the outside to drill thru, so i drilled on the angle over too the headstud from the face of the head.. worked a treat..
Posted on: 2009/8/4 1:21
A15 PSI Project Motor
'72 CB750k,
The newer heads don't have room to drill straight up + straight over. Here's a pic:
Early Head:
Late Head (no boss):
Posted on: 2009/8/4 3:18
From Delaware, USA
Yep, 1 hole is all it took. Actually it has a better lubrication than before. Like you said, the oil now shoots straight up the 45 angle hole than 2 holes. Cheers. :)
Posted on: 2009/8/4 13:11
From Freo
just have to use caution and not use too much angle and break thru the outside... !!!
Posted on: 2009/8/4 15:16
'72 CB750k,
Is it like this? I think this head is drilled 45 degrees.
Fully Serviced Head
Posted on: 2009/8/8 21:20
« 1 (2)
