#1 120y Auto Shaft To Stanza Box No Go, Help ??
DatsAndy Posted on: 2009/8/9 9:16
Got 120y BW68 diff in me 1200 sedan with stanza 4 speed and stanza L16. Motor and box are in mounted but 120y Auto tail shaft is like an inch and a quarter to long. Any advice or other options Please ? If anything motor needs to go down a bit more and back but that will add to the drama obviously.
#2 Re: 120y Auto Shaft To Stanza Box No Go, Help ??
revhead001 Posted on: 2009/8/9 10:02
What diff?
#3 Re: 120y Auto Shaft To Stanza Box No Go, Help ??
DatsAndy Posted on: 2009/8/9 10:14
120y Borg Warner
#4 Re: 120y Auto Shaft To Stanza Box No Go, Help ??
PIGDOG Posted on: 2009/8/9 12:51
sean, whitesedan, is running stock auto shafts in his cars i think...so it should work
#5 Re: 120y Auto Shaft To Stanza Box No Go, Help ??
Posted on: 2009/8/9 12:52
opps double
#6 Re: 120y Auto Shaft To Stanza Box No Go, Help ??
DatsAndy Posted on: 2009/8/9 13:13
Should but doesnt. The stumpy 5 speed box i have is near exactly the distance shorter that i need it to be but no L housing to bolt on to it. So this conversion may get the sack in exchange for an SR20 with stumpy box convo.
#7 Re: 120y Auto Shaft To Stanza Box No Go, Help ??
revhead001 Posted on: 2009/8/9 13:19
I ran a stock auto shaft in mine. It worked with both the R30 box and the stanza 5 banger. Is your box the 660mm box (stumpy) or the longer box? My engine was sitting about 25mm from the firewall. although 120Y but they are ll the same distance wise in that respect.
#8 Re: 120y Auto Shaft To Stanza Box No Go, Help ??
PIGDOG Posted on: 2009/8/9 13:23
so your saying that the stanza 4 speed is longer than an L series stumpy?
think it would probably be a bit easier to get an L series bellhousing than it would be to redo the conversion....not like they are really rare or even hard to find
#9 Re: 120y Auto Shaft To Stanza Box No Go, Help ??
DatsAndy Posted on: 2009/8/10 1:03
Yes its an inch and a bit longer but the stumpy here has the Ca bell housing on it. So o.k probably been here before but what L bell housing options do i have to bolt on to the Stumpy ?. L's Bells
#10 Re: 120y Auto Shaft To Stanza Box No Go, Help ??
PIGDOG Posted on: 2009/8/10 2:07
any 71 series 5 speed bellhousing, which is pretty much all L series 5 speeds apart from the sss stanza one or 180b sss box
so from what ive had, bluebird, 720, z cars, 240k, r30(obviously) and im sure there are other
(1) 2 3 »
