What is the Max BHP ?
From Sri Lanka
Hi Guys
Just Like to see what is the Max BHP you get on your datsun with what motor and configuration ?
Thanks
Regards
sumith
Posted on: 2009/8/11 11:46
Re: What is the Max BHP ?
From newcastle, NSW
Theres a guy in QLD, from Yatla Head worx that has got 300Hp+ out of an A-series. It is fuel injected running a big turbo and a fair amount of work done to it to reach that amount of performance.
I spose the sky is the limit! depending on how much you want to spend on it.
Posted on: 2009/8/11 12:05
From Sydney, Australia
"I spose the sky is the limit! depending on how much you want to spend on it."
..and how long you want it to last
Race motors get big horsepower because they only last a few races.
You don't want that engine in your daily driver!
Posted on: 2009/8/11 12:13
From tassie
well I just pulled down our 12a after three race seasons motor was not balanced was only bored 40 thou, flat top pistons and running at 7.5.1 reving to 7700 every race standared head and carb dont know what power but who cares when you can rev a motor like that every time it runs and not blow these are truly remarkable engines.
Posted on: 2009/8/11 13:10
From south coast nsw
12a dosent havent pistons?a12 do u mean?7.5:1 for n/a race motor?id be stoked with 100 at the wheels on a tightish parts budget.
Posted on: 2009/8/11 15:20
From sydney.nsw
Im sure dad-sun was talking about a A12 DATSUN engine.
Posted on: 2009/8/11 21:56
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From Geelong, Vic
mmm7.5:1 comp ratio on an NA engine would be mighty slow lol
100hp at the wheel out of an A12...or any A series really, will cost you a little bit. dont think it would really be that achievable on a tight budget if its NA
Posted on: 2009/8/12 3:06
max hp is unlimited funds for little pushrod engine
Posted on: 2009/8/12 5:51
From tassie
oops yes i did mean a12 just bieng a bit brain dead mmm yep it was a little slow but it set a lap record on the 440 m clay track in hobart of 18.89 seconds running in second gear so it is not that bad hopefully with the new build it will have a lot more grunt once the season is under way, and the aust title is run we will start a post for other kids that are running these engines so they can have a little bit of a head start with what to look for and what not to do along with this info I will give full credit to the shops and persons that are helping us because as we have found we can build a motor that works very well without spending big big dollars we will also have dyno results on the new motor.
Posted on: 2009/8/12 11:35
From Southern Highlands, NSW, Australia
When I was tuning my racecar I saw about 120hp at the wheels at 6500rpm. Didn't rev it any further but could be making a little bit more at higher revs.
Posted on: 2009/8/12 12:07
'72 1200 sedan hillclimb/supersprint car
(1) 2 3 »
