Browsing this Thread:
1 Anonymous Users
Re: 5 speed synchros |
From brisbane
Redline gear oil is supposedly good for worn boxes. I haven't used it before however.
Posted on: 2009/8/11 10:26
1985 CA18DET Datsun 1200 ute 1969 A12 Datsun 1000 coupe
Yeah, and about $220 for 4 litres!!
Posted on: 2009/8/11 11:04
From NZ
If you have a good workshop manual, some basic tools, and are mechanically minded Datsun box's are goo dto work on.
I'd try an oil change first though. Make sure you use GL4 not GL5.
Posted on: 2009/8/12 12:09
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box. Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
From sydney australia
I've always used Castrol Syntrans, especially when I was running the 56a 5 speed. It was the only thing that would get any life out of the bearings, I went from new bearings every second meeting to getting a whole year out of the box without the bearings even getting noisy. You can get it from Repco in litre bottles, you need 2 bottles. It won't cure a worn synchro, but it'll make it a little easier to get the gear. I know this from experience, as the 60a 5 speed I had in a car had a dud synchro, & it worked a bit easier with the Syntrans.
Posted on: 2009/8/13 1:40
From illawarra, nsw australia
Im taking the box to get it rebuilt on monday With this oil you say is good and the way i drive it should last a long time! And will be worth the fuss once its over
Thanks Jason
Posted on: 2009/8/13 4:02
From Seattle ,WA.
just out of curiosity how much for the rebuild on the box & whats included?
Posted on: 2009/8/14 16:44
From Freo
for Penrite gear oils, I've always had good results, Manual Gear Oil 80 (SAE 80W-85)was known as MGO Light. Manual Gear Oil 75 (SAE 75W-80), which was known as Manual Gear Oil Extra Light
Posted on: 2009/8/20 2:26
'68 Thou Wagon,(home now) up and running '69 2 door project, the yellow thing, A12A Project motor, for the yellow thing. A15 PSI Project Motor '72 CB750k,
ok thanks guys
will write a list and spend some time shopping for oil this weekend and see what i can find! (or cant find)
Posted on: 2009/8/20 3:21
