« 1 ... 6 7 8 (9) 10 11 12 ... 15 »
Re: SR20DET Sunny
From malta
the clutch at the moment is a cable one but u need to change to hydraulic. u have to buy ur self a pedal fron a 240sx and master cylinder
Posted on: 2009/8/12 19:01
Re: SR20DET Sunny
From sydney australia
In one of the other threads there's a picture of the pedal box from a 120Y (b210) manual pedal box, that had all the mounts for a hydraulic clutch. It was a thread about fitting a gearbox into an auto 120Y. I don't know if this is an Australian only feature, or if it's world wide, but it could be a go for a 'bolt in' clutch. It looked suspiciously like the A10 Stanza pedal box I used in my Sunny Coupe.Got a 78 120Y outside, think I'll have a look.
Posted on: 2009/8/13 1:13
Re: SR20DET Sunny
Just had a look at the 78 sedan out the front, it has the studs & mounting hardware for a hydraulic clutch, but not the hole through the firewall. I seem to remember that the 73 120Y coupe my friend has doesn't have this set up. It'd be nice to know if this is a world wide thing, as I'm pretty sure 120Y's were sold in Malta. I'll have to get one anyway, as I still don't have the pedal box for my SR20 powered sedan. I always use an auto brake pedal in my Sunny's, I wonder if there's enough room with the 120Y pedal box.
Posted on: 2009/8/13 1:27
Re: SR20DET Sunny
From Adelaide
^^^ So the reservoir etc. mounts to the inside on the pedals, yeah?
Posted on: 2009/8/13 11:51
To increase speed, add lightness.
Re: SR20DET Sunny
No, you'd still have to mount the master cylinder in the engine bay, so you'd have make a hole in the firewall, but all the bits are there.the standard sunny pedal box isn't adaptable. the Stanza one is wider & covers the hole that the speedo cable goes through, so maybe the 120y will be a bit narrower. They're also easier to get than Stanza parts. I'm going to have a look at a few cars in wreckers this afternoon, should take a tape measure with me.
Posted on: 2009/8/14 1:23
Re: SR20DET Sunny
From Adelaide
Ah ok. I saw one chap mount the hardware inside onto the pedal box. Only problem i have is the room between the firewall and inlet manifold. Its very tight. Will check the wreckers myself for the 120Y & check the set-up. Also need to have a look at a Skyline to check the handbrake linkages...
Posted on: 2009/8/16 14:02
Re: SR20DET Sunny
From malta
skyline have drum handbreak and disc is only dedicated for breaking.
its a 2 in one combo
there is a couple of 120y in good condition here in malta. a 240sx and a b310 clutch master cylinder are the same in size and working order
Posted on: 2009/8/17 20:38
Re: SR20DET Sunny
From Christchurch
r32/33/34 on has the separate drum setup, the r31's are a conventional setup.
Posted on: 2009/8/17 21:21
Re: SR20DET Sunny
From malta
hey buddy. how is ur project going on? unfortunately mine is on break since i m spending alot of time at work, hopefully i will be continuing it next month. hope everyone is doing fine in here
Posted on: 2009/10/20 19:03
Re: SR20DET Sunny
From Adelaide
Mine is on a forced break as I can't move it at the moment and my garage is too small to work in. The diff is out & until it goes back in things are at a standstill. Just bought a few small parts & whatnot.. Def still forging on with it!
Posted on: 2009/10/24 9:34
